[petsc-users] A few questions about hdf5 viewer
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Thu Jan 19 02:50:51 CST 2012
Hi guys,
I have compiled petsc to use HDF5 package.
I like to store the data from a parallel vector(s) (obtained from
structured DA in 3 dimensions) to file using VecView() in conjunction
with PetscViewerHDF5Open().
I followed the example here
http://www.mcs.anl.gov/petsc/petsc-current/src/dm/examples/tutorials/ex10.c.html
and everything looks fine.
However, I had a couple questions:
1- When I am done writing the parallel vector obtained from the DA (and
PETSC_COMM_WORLD),
// Create the HDF5 viewer
PetscViewerHDF5Open<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerHDF5Open.html#PetscViewerHDF5Open>
(PETSC_COMM_WORLD<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>
,"gauss.h5",FILE_MODE_WRITE,&H5viewer);
// Write the H5 file
   VecView<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecView.html#VecView>
(gauss,H5viewer);
// Cleaning stage
PetscViewerDestroy<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerDestroy.html#PetscViewerDestroy>
(&H5viewer);
how can I add data that are just simple 1-D numbers stored on local arrays.
Easier said, I would like to add the structured grid coordinates (first all
x's, then all y's, and then all z's) at the end (or to the beginning) of
each data (*.h5) file. But the grid coordinates are stored locally on each
machine and not derived from any parallel vectors or DA. I was thinking
about creating vectors and viewers using PETSC_COMM_SELF but i am not sure
if that is the right approach since that vector is created on all
processors locally.
2- When using VecView() and HDF5 writer, what is the status of data
compression?
The reason that I am asking is that, I used the same example above and
comparing two files saved via two different PetscViewers, i.e. (just)
Binary and HDF5 (Binary) the size is not reduced in the (*.h5) case.
In fact, it is slightly bigger than pure binary file!!
Is there any command we have to set in Petsc to tell HDF5 viewer to use
data compression?
Thanks for your patience,
Best,
Mohamad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120119/3c7c2fc1/attachment-0001.htm>
