[petsc-users] generate entries on 'wrong' process (Barry Smith)
Wen Jiang jiangwen84 at gmail.com
Wed Jan 18 14:22:59 CST 2012
Hi Barry,
The symptom of "just got stuck" is simply that the code just stays there
and never moves on. One more thing is that all the processes are at 99% cpu
utilization. I do see some network traffic between the head node and
computation nodes. The quantity is very small, but the sheer number of
packets is huge. The processes are sending between 550 and 620 Million
packets per second across the network.
Since my code never finishes, I cannot get the summary files by add
-log_summary. any other way to get summary file?
BTW, my codes are running without any problem on shared-memory desktop with
any number of processes.
On Wed, Jan 18, 2012 at 3:03 PM, <petsc-users-request at mcs.anl.gov> wrote:
> Send petsc-users mailing list submissions to
>        petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>        https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>   1. Re:  generate entries on 'wrong' process (Barry Smith)
>   2. Re:  [petsc-dev] boomerAmg scalability (Ravi Kannan)
> Message: 1
> Date: Wed, 18 Jan 2012 12:56:10 -0600
> From: Barry Smith <bsmith at mcs.anl.gov>
> Subject: Re: [petsc-users] generate entries on 'wrong' process
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID: <47754349-9741-4740-BBB4-F4B84EA07CEF at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
>   What is the symptom of "just got stuck".   Send the results of the whole
> run with -log_summary to petsc-maint at mcs.anl.gov and we'll see how much
> time is in that communication.
>    Barry
> On Jan 18, 2012, at 10:32 AM, Wen Jiang wrote:
> > Hi,
> > I am working on FEM codes with spline-based element type. For 3D case,
> one element has 64 nodes and every two neighboring elements share 48 nodes.
> Thus regardless how I partition a mesh,  there are still very large number
> of entries that have to write on the 'wrong' processor. And my code is
> running on clusters, the processes are sending between 550 and 620 Million
> packets per second across the network. My code seems IO-bound at this
> moment and  just get stuck at the matrix assembly stage. A -info file is
> attached. Do I have other options to optimize my codes to be less
> io-intensive?
> > Thanks in advance.
> > [0] VecAssemblyBegin_MPI(): Stash has 210720 entries, uses 12 mallocs.
> > [0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
> > [5] MatAssemblyBegin_MPIAIJ(): Stash has 4806656 entries, uses 8 mallocs.
> > [6] MatAssemblyBegin_MPIAIJ(): Stash has 5727744 entries, uses 9 mallocs.
> > [4] MatAssemblyBegin_MPIAIJ(): Stash has 5964288 entries, uses 9 mallocs.
> > [7] MatAssemblyBegin_MPIAIJ(): Stash has 7408128 entries, uses 9 mallocs.
> > [3] MatAssemblyBegin_MPIAIJ(): Stash has 8123904 entries, uses 9 mallocs.
> > [2] MatAssemblyBegin_MPIAIJ(): Stash has 11544576 entries, uses 10
> mallocs.
> > [0] MatStashScatterBegin_Private(): No of messages: 1
> > [0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 107888648
> > [0] MatAssemblyBegin_MPIAIJ(): Stash has 13486080 entries, uses 10
> mallocs.
> > [1] MatAssemblyBegin_MPIAIJ(): Stash has 16386048 entries, uses 10
> mallocs.
> > [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space:
> 0 unneeded,2514537 used
> > [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [0] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using
> Inode routines
> > [5] MatAssemblyEnd_SeqAIJ(): Matrix size: 11390 X 11390; storage space:
> 0 unneeded,2525390 used
> > [5] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [5] Mat_CheckInode(): Found 11390 nodes out of 11390 rows. Not using
> Inode routines
> > [3] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space:
> 0 unneeded,2500281 used
> > [3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [3] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using
> Inode routines
> > [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space:
> > [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [1] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using
> Inode routines
> > [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space:
> > [4] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [4] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using
> Inode routines
> > [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space:
> 0 unneeded,2525733 used
> > [2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
> > [2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
> > [2] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using
> Inode routines
> > <petsc_info>
> Message: 2
> Date: Wed, 18 Jan 2012 14:03:43 -0600
> From: "Ravi Kannan" <rxk at cfdrc.com>
> Subject: Re: [petsc-users] [petsc-dev] boomerAmg scalability
> To: "'Mark F. Adams'" <mark.adams at columbia.edu>
> Cc: 'PETSc users list' <petsc-users at mcs.anl.gov>
> Message-ID: <006f01ccd61c$47c0fc80$d742f580$@com>
> Content-Type: text/plain; charset="us-ascii"
> Hi Mark, Hong,
> As you might remember, the reason for this whole exercise was to obtain a
> solution for a very stiff problem.
> We did have Hypre Boomer amg. This did not scale, but gives correct
> solution. So we wanted an alternative; hence we approached you for gamg.
> However for certain cases, gamg crashes. Even for the working cases, it
> takes about 15-20 times more sweeps than the boomer-hypre. Hence it is
> cost-prohibitive.
> Hopefully this gamg solver can be improved in the near future, for users
> like us.
> Warm Regards,
> Ravi.
> From: Mark F. Adams [mailto:mark.adams at columbia.edu]
> Sent: Wednesday, January 18, 2012 9:56 AM
> To: Hong Zhang
> Cc: rxk at cfdrc.com
> Subject: Re: [petsc-dev] boomerAmg scalability
> Hong and Ravi,
> I fixed a bug with the 6x6 problem.  There seemed to be a bug in
> MatTranposeMat with funny decomposition, that was not really verified.  So
> we can wait for Ravi to continue with his tests a fix them as they arise.
> Mark
> ps, Ravi, I may not have cc'ed so I will send again.
> On Jan 17, 2012, at 7:37 PM, Hong Zhang wrote:
> Ravi,
> I wrote a simple test ex163.c (attached) on MatTransposeMatMult().
> Loading your 6x6 matrix gives no error from MatTransposeMatMult()
> using 1,2,...7 processes.
> For example,
> petsc-dev/src/mat/examples/tests>mpiexec -n 4 ./ex163 -f
> /Users/hong/Downloads/repetscdevboomeramgscalability/binaryoutput
> A:
> Matrix Object: 1 MPI processes
>  type: mpiaij
> row 0: (0, 1.66668e+06)  (1, -1.35)  (3, -0.6)
> row 1: (0, -1.35)  (1, 1.66667e+06)  (2, -1.35)  (4, -0.6)
> row 2: (1, -1.35)  (2, 1.66667e+06)  (5, -0.6)
> row 3: (0, -0.6)  (3, 1.66668e+06)  (4, -1.35)
> row 4: (1, -0.6)  (3, -1.35)  (4, 1.66667e+06)  (5, -1.35)
> row 5: (2, -0.6)  (4, -1.35)  (5, 1.66667e+06)
> C = A^T * A:
>  type: mpiaij
> row 0: (0, 2.77781e+12)  (1, -4.50002e+06)  (2, 1.8225)  (3, -2.00001e+06)
> (4, 1.62)
> row 1: (0, -4.50002e+06)  (1, 2.77779e+12)  (2, -4.50001e+06)  (3, 1.62)
> (4, -2.00001e+06)  (5, 1.62)
> row 2: (0, 1.8225)  (1, -4.50001e+06)  (2, 2.7778e+12)  (4, 1.62)  (5,
> -2.00001e+06)
> row 3: (0, -2.00001e+06)  (1, 1.62)  (3, 2.77781e+12)  (4, -4.50002e+06)
> (5, 1.8225)
> row 4: (0, 1.62)  (1, -2.00001e+06)  (2, 1.62)  (3, -4.50002e+06)  (4,
> 2.77779e+12)  (5, -4.50001e+06)
> row 5: (1, 1.62)  (2, -2.00001e+06)  (3, 1.8225)  (4, -4.50001e+06)  (5,
> 2.7778e+12)
> Do I miss something?
> Hong
> On Sat, Jan 14, 2012 at 3:37 PM, Mark F. Adams <mark.adams at columbia.edu>
> wrote:
> Ravi, this system is highly diagonally dominate.  I've fixed the code so
> you
> can pull and try again.
> I've decided to basically just do a one level method with DD systems.  I
> don't know if that is the best semantics, I think Barry will hate it,
> because it gives you a one level solver when you asked for MG.  It now
> picks
> up the coarse grid solver as the solver, which is wrong, so I need to fix
> this if we decide to stick with the current semantics.
> And again thanks for helping to pound on this code.
> Mark
> On Jan 13, 2012, at 6:33 PM, Ravi Kannan wrote:
> Hi Mark, Hong,
> Lets make it simpler. I fixed my partitiotion bug (in metis). Now there is
> a
> equidivision of cells.
> To simplify even further, lets run a much smaller case : with 6 cells
> (equations) in SERIAL. This one crashes. The out and the ksp_view_binary
> files are attached.
> Thanks,
> RAvi.
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov]
> On Behalf Of Mark F. Adams
> Sent: Friday, January 13, 2012 3:00 PM
> To: For users of the development version of PETSc
> Well, we do have a bug here.  It should work with zero elements on a proc,
> but the code is being actively developed so you are really helping us to
> find these cracks.
> If its not too hard it would be nice if you could give use these matrices,
> before you fix it, so we can fix this bug.  You can just send it to Hong
> and
> I (cc'ed).
> Mark
> On Jan 13, 2012, at 12:16 PM, Ravi Kannan wrote:
> Hi Mark,Hong
> Thanks for the observation w.r.t the proc 0 having 2 equations. This is a
> bug from our end. We will fix it and get back to you if needed.
> Thanks,
> Ravi.
> Sent: Thursday, January 12, 2012 10:03 PM
> To: Hong Zhang
> Cc: For users of the development version of PETSc
> Ravi, can you run with -ksp_view_binary? This will produce two files.
> Hong, ex10 will read in these files and solve them.  I will probably not be
> able to get to this until Monday.
> Also, this matrix has just two equations on proc 0 and and about 11000 on
> proc 1 so its is strangely balanced, in case that helps ...
> Mark
> On Jan 12, 2012, at 10:35 PM, Hong Zhang wrote:
> Ravi,
> I need more info for debugging. Can you provide a simple stand alone code
> and matrices in petsc
> binary format that reproduce the error?
> MatTransposeMatMult() for mpiaij is a newly developed subroutine - less
> than
> one month old
> and not well tested yet :-(
> I used petsc-dev/src/mat/examples/tests/ex94.c for testing.
> Thanks,
> Hong
> On Thu, Jan 12, 2012 at 9:17 PM, Mark F. Adams <mark.adams at columbia.edu>
> wrote:
> It looks like the problem is in MatTransposeMatMult and Hong (cc'ed) is
> working on it.
> I'm hoping that your output will be enough for Hong to figure this out but
> I
> could not reproduce this problem with any of my tests.
> If Hong can not figure this out then we will need to get the matrix from
> you
> to reproduce this.
> Mark
> On Jan 12, 2012, at 6:25 PM, Ravi Kannan wrote:
> Hi Mark,
> Any luck with the gamg bug fix?
> Thanks,
> Ravi.
> Sent: Wednesday, January 11, 2012 1:54 PM
> This seems to be dying earlier than it was last week, so it looks like a
> new
> bug in MatTransposeMatMult.
> Mark
> On Jan 11, 2012, at 1:59 PM, Matthew Knepley wrote:
> On Wed, Jan 11, 2012 at 12:23 PM, Ravi Kannan <rxk at cfdrc.com> wrote:
> Hi Mark,
> I downloaded the dev version again. This time, the program crashes even
> earlier. Attached is the serial and parallel info outputs.
> Could you kindly take a look.
> It looks like this is a problem with MatMatMult(). Can you try to reproduce
> this using KSP ex10? You put
> your matrix in binary format and use -pc_type gamg. Then you can send us
> the
> matrix and we can track
> it down. Or are you running an example there?
>  Thanks,
>    Matt
> Thanks,
> Ravi.
> Sent: Monday, January 09, 2012 3:08 PM
> Yes its all checked it, just pull from dev.
> Mark
> On Jan 9, 2012, at 2:54 PM, Ravi Kannan wrote:
> Hi Mark,
> Thanks for your efforts.
> Do I need to do the install from scratch once again? Or some particular
> files (check out gamg.c for instance)?
> Thanks,
> Ravi.
> Sent: Friday, January 06, 2012 10:30 AM
> I think I found the problem.  You will need to use petsc-dev to get the
> fix.
> Mark
> On Jan 6, 2012, at 8:55 AM, Mark F. Adams wrote:
> Ravi, I forgot but you can just use -ksp_view_binary to output the matrix
> data (two files).  You could run it with two procs and a Jacobi solver to
> get it past the solve, where it writes the matrix (I believe).
> Mark
> On Jan 5, 2012, at 6:19 PM, Ravi Kannan wrote:
> Just send in another email with the attachment.
> On Behalf Of Jed Brown
> Sent: Thursday, January 05, 2012 5:15 PM
> On Thu, Jan 5, 2012 at 17:12, Ravi Kannan <rxk at cfdrc.com> wrote:
> I have attached the verbose+info outputs for both the serial and the
> parallel (2 partitions). NOTE: the serial output at some location says
> PC=Jacobi! Is it implicitly converting the PC to a Jacobi?
> Looks like you forgot the attachment.
> experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
> <out><binaryoutput><binaryoutput.info <http://binaryoutput.info/> >
> <ex163.c>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120118/965a1679/attachment.htm
> End of petsc-users Digest, Vol 37, Issue 41
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120118/184102a2/attachment.htm>
