[petsc-users] generate entries on 'wrong' process
Wen Jiang jiangwen84 at gmail.com
Wed Jan 18 10:32:45 CST 2012
I am working on FEM codes with spline-based element type. For 3D case, one
element has 64 nodes and every two neighboring elements share 48 nodes.
Thus regardless how I partition a mesh,  there are still very large number
of entries that have to write on the 'wrong' processor. And my code is
running on clusters, the processes are sending between 550 and 620 Million
packets per second across the network. My code seems IO-bound at this
moment and  just get stuck at the matrix assembly stage. A -info file is
attached. Do I have other options to optimize my codes to be less
io-intensive?
Thanks in advance.
[0] VecAssemblyBegin_MPI(): Stash has 210720 entries, uses 12 mallocs.
[0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
[5] MatAssemblyBegin_MPIAIJ(): Stash has 4806656 entries, uses 8 mallocs.
[6] MatAssemblyBegin_MPIAIJ(): Stash has 5727744 entries, uses 9 mallocs.
[4] MatAssemblyBegin_MPIAIJ(): Stash has 5964288 entries, uses 9 mallocs.
[7] MatAssemblyBegin_MPIAIJ(): Stash has 7408128 entries, uses 9 mallocs.
[3] MatAssemblyBegin_MPIAIJ(): Stash has 8123904 entries, uses 9 mallocs.
[2] MatAssemblyBegin_MPIAIJ(): Stash has 11544576 entries, uses 10 mallocs.
[0] MatStashScatterBegin_Private(): No of messages: 1
[0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 107888648
[0] MatAssemblyBegin_MPIAIJ(): Stash has 13486080 entries, uses 10 mallocs.
[1] MatAssemblyBegin_MPIAIJ(): Stash has 16386048 entries, uses 10 mallocs.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2514537 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[0] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 11390 X 11390; storage space: 0
unneeded,2525390 used
[5] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[5] Mat_CheckInode(): Found 11390 nodes out of 11390 rows. Not using Inode
routines
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2500281 used
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[3] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[1] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[4] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
[4] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[4] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2525733 used
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[2] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120118/14cccc04/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120118/14cccc04/attachment-0001.obj>
