[petsc-users] To store the RHS vector b of KSPSolve.
Xuefei (Rebecca) Yuan xyuan at lbl.gov
Tue Jan 17 15:01:39 CST 2012
Hello Matt,
On Jan 17, 2012, at 12:53 PM, Matthew Knepley wrote:
> On Tue, Jan 17, 2012 at 2:51 PM, Xuefei (Rebecca) Yuan <xyuan at lbl.gov> wrote:
> Hello all,
> I have a piece of code that need to store the RHS vector b of the ksp object via vecview.
> However, the routine is like:
>        ierr = DMMGSetSNESLocal(dmmg, FormFunctionLocal, FormJacobianLocal,0,0);CHKERRQ(ierr);
>        ierr = DMMGSolve(dmmg);CHKERRQ(ierr);
> The rhs evaluation is in FormFunctionLocal(), how could store the rhs vector b?
> 1) In your nonlinear problem, what do you mean by b?
This b is refer to the linear problem's rhs, i.e., for the nonlinear problem F(u)=0 is the residual evaluation in FormFunctionLocal, and for the linear solver, Ax=b, this rhs vector b is -F(u^{k]), k is the iteration number for the nonlinear solver.
I want to separate the Jacobian matrix and the rhs vector from the very beginning for testing some linear solver:
******* start solving for time = 0.50000 at time step = 1******
  0 SNES Function norm 1.242539468950e-02
start saving jacobian
Linear solve converged due to CONVERGED_ITS iterations 1
  1 SNES Function norm 3.341795546738e-05
  2 SNES Function norm 1.329755764187e-08
  3 SNES Function norm 3.067585609727e-12
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
The jacobian matrix was saved before calling the linear solver provided by PETSc, and I need to get the corresponding rhs vector b with this jacobian matrix.
> 2) Don't use DMMG, use petsc-dev with regular SNES and SNESSetDM()
I will look into that later.
>    Matt
Thanks very much!
Best regards,
Rebecca
> Thanks very much!
> Cheers,
> Rebecca
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120117/3b5436f2/attachment-0001.htm>
