[petsc-users] unstructured finite volume method matrix assembly for partitioned mesh
Tue Jan 17 12:41:32 CST 2012
On Tue, Jan 17, 2012 at 12:26 PM, Rahul Praghanmor <praghanmor at gmail.com>wrote:
> Dear Sir,
>           I am working on a parallel unstructured finite volume solver.The
> solver is efficiently running in parallel using gauss seidel linear
> solver.The matrix is sparse and stored by CSR format.Now I want to
> implement a PETSc library to make the convergence faster.But I am going
> through a major problem as discussed below.
>           If I partitioned a big domain say rectangular duct into 4 zones
> using parMetis.Each zone is solved in separate processor as fairly solved
> by gauss seidel linear solver.But I want to solve these zones by PETSc.How
> to do that?How to form a matrix with global numbering which is required
> format for PETSc to form a matrix?Does it necessarily important to form a
> global matrix? very few information available for assembling a matrix from
> unstructured finite volume method in PETSc.
If you already run ParMetis, just number the rows it puts on each process
consecutively.
   Matt
> Thankx and regards,
> Rahul.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120117/f3c1f5dc/attachment.htm>
