[petsc-users] DMGetMatrix segfault
Klaij, Christiaan C.Klaij at marin.nl
Tue Jan 17 01:44:10 CST 2012
I'm learning to use DMs, below is a first try but it gives a segfault. Any ideas?
#include <petscdmda.h>
int main(int argc, char **argv)
  DM               da0, da1;
  DMDABoundaryType bx = DMDA_BOUNDARY_PERIODIC, by = DMDA_BOUNDARY_PERIODIC;
  DMDAStencilType  stype = DMDA_STENCIL_STAR;
  PetscInt         Mx = 8, My = 8;
  PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);
  // create distributed array for Mx-by-My grid
  DMDACreate2d(PETSC_COMM_WORLD,bx,by,stype,Mx,My,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL,PETSC_NULL,&da0);
  DMDACreate2d(PETSC_COMM_WORLD,bx,by,stype,Mx,My,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL,PETSC_NULL,&da1);
  // mat nest from pack
  DM  pack;
  Mat A;
  DMCompositeCreate(PETSC_COMM_WORLD,&pack);
  DMCompositeAddDM(pack,da0);
  DMCompositeAddDM(pack,da1);
  DMGetMatrix(pack,MATNEST,&A);
  MatView(A,PETSC_VIEWER_DEFAULT);
  PetscFinalize();
  return 0;
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] DMCompositeGetISLocalToGlobalMappings line 798 src/dm/impls/composite/pack.c
[0]PETSC ERROR: [0] DMCreateLocalToGlobalMapping_Composite line 1490 src/dm/impls/composite/pack.c
[0]PETSC ERROR: [0] DMGetLocalToGlobalMapping line 355 src/dm/interface/dm.c
[0]PETSC ERROR: [0] DMGetMatrix_Composite line 222 src/dm/impls/composite/packm.c
[0]PETSC ERROR: [0] DMGetMatrix line 569 src/dm/interface/dm.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./dmda-try3 on a linux_64b named lin0133 by cklaij Tue Jan 17 08:34:36 2012
[0]PETSC ERROR: Libraries linked from /opt/refresco/64bit_intelv11.1_openmpi/petsc-3.2-p5/lib
[0]PETSC ERROR: Configure run at Mon Jan 16 14:03:34 2012
[0]PETSC ERROR: Configure options --prefix=/opt/refresco/64bit_intelv11.1_openmpi/petsc-3.2-p5 --with-mpi-dir=/opt/refresco/64bit_intelv11.1_openmpi/openmpi-1.4.4 --with-x=0 --with-mpe=0 --with-debugging=1 --with-hypre-include=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/include --with-hypre-lib=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/lib/libHYPRE.a --with-ml-include=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/include --with-ml-lib=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/lib/libml.a --with-blas-lapack-dir=/opt/intel/mkl
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpiexec has exited due to process rank 0 with PID 1445 on
node lin0133 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
