[petsc-users] [petsc-maint #101696] complex + float128
Sun Jan 15 10:43:36 CST 2012
On Sun, Jan 15, 2012 at 05:54, Xavier Garnaud <
xavier.garnaud at ladhyx.polytechnique.fr> wrote:
> Thank you for your help.
> quadmath.h contains quad complex functions. I naively added the functions
> for quad complex. The beginning of the compilation works, but then it fails
> with an MPI related error. I will contact you again when i manage to make
> it work,
What was the MPI error?
It's likely that we are missing data types and MPI_Ops for quad complex.
> Sincerely,
> Xavier
> On Mon, Jan 9, 2012 at 8:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   We've never tried to do this.
>>    First you need to check if quadmath.h has quad complex stuff in it? If
>> it does you need to add into petscmath.h the quad complex bindings for all
>> the various math operations like PetscScalar and PetscSqrtScalar() etc
>>   Barry
>> On Jan 9, 2012, at 12:05 PM, Xavier Garnaud wrote:
>> > I am trying to build PETSc with complex number and quadruple precision,
>> but
>> > I get an error at the compiling stage. I do not get this error when I do
>> > the same using real numbers. Are complex numbers incompatible with
>> > quadruple precision?
>> > Thank you very much,
>> > Sincerely,
>> > Xavier
>> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120115/3649f300/attachment.htm>
