[petsc-users] 3.2-p6
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Wed Jan 11 10:03:16 CST 2012
Ok Great thank, I can't see it on the main web page, should I look
elsewhere?
Cheers,
Andy
-----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
Sent: 11 January 2012 16:01
To: PETSc users list
Subject: Re: [petsc-users] 3.2-p6
                    *** WARNING ***
  This message has originated outside your organisation,
  either from an external partner or the Global Internet.
      Keep this in mind if you answer this message.
  To report a suspicious email, follow the instructions
  on the Global Intranet at "<How We Work> / <Security>"
petsc-3.2-p6 tarball is now available for download.
And yes - it should have the patch you mention.
Satish
On Wed, 11 Jan 2012, Parker, Andrew (UK Filton) wrote:
> Hi,
> Just before Christmas I was kindly provided a patch for the pbjacob
> method for 7x7 matrices: pbjacobi.patch.  I applied this to 3.2-p5 at
it
> worked fine, but I wonder when/if it will make it to a release and if
so
> will it be on p6?  When is p6 scheduled as I need to plan an internal
> release based on this?
> Cheers again,
> Andy
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
