[petsc-users] 3.2-p6
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Wed Jan 11 04:36:36 CST 2012
Just before Christmas I was kindly provided a patch for the pbjacob
method for 7x7 matrices: pbjacobi.patch.  I applied this to 3.2-p5 at it
worked fine, but I wonder when/if it will make it to a release and if so
will it be on p6?  When is p6 scheduled as I need to plan an internal
release based on this?
Cheers again,
Andy
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120111/9590153c/attachment.htm>
