[petsc-users] Strongly nonlinear equation solved within the framework of PETSc
Tue Jan 10 22:23:06 CST 2012
On Tue, Jan 10, 2012 at 03:27, Fatcharm <wolfshow at gmail.com> wrote:
> It is weird that if I run with -snes_converged_reason, I got
> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH
> If I run with  -snes_converged_reason and -info I found that
> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
Wait, identical options except for -info are giving different results?
This sounds like a memory error, could you try Valgrind?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120110/e88beef0/attachment.htm>
