[petsc-users] Convergence/accuracy degradation with increasing number of procs
Mon Jan 9 10:36:19 CST 2012
On Mon, Jan 9, 2012 at 10:31 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> I have tested default GMRES+ILU(0) solver for problem of size ~200000 and
> I observed that both convergence rate and accuracy degrade when I increase
> number of processes.
> E.g., number of iterations almost doubles when going from 1 to 4
> processors.
> I noticed that ILU(0) is somehow represented by sequential matrices
> internally and feel that this might be a reason?
The default is Block Jacobi+ILU(0) and GMRES(30) which will definitely
degrade as the number of
processes is increased. You would need to use an optimal preconditioner
like Multigrid if you want
a constant number of iterates.
   Matt
> Regards,
> Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120109/1d556ad6/attachment-0001.htm>
