[petsc-users] Software for load balancing to improve parallel performance to be used with PETSc
TAY wee-beng zonexo at gmail.com
Mon Jan 9 09:57:40 CST 2012
Hi Jed,
On 5/1/2012 4:59 PM, Jed Brown wrote:
> On Thu, Jan 5, 2012 at 09:41, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     I just did a -log_summary and attach the text file, running across
>     8 and 16 processors. My most important concern is whether the load
>     is balanced across the processors.
>     In 16 processors case, for the time, it seems that the ratio for
>     many events are higher than 1, reaching up to 6.8 for VecScatterEnd
> This takes about 1% of the run time and it's scaling well, so don't
> worry about it.
>     and 132.1 (?) for MatAssemblyBegin.
> This is about 2% of run time, but it's not scaling. Do you compute a
> lot of matrix entries on processes that don't own the rows?
I only compute rows which the processor own. Can it be the memory
allocation? I'll check on that.
> Most of your solve time is going into PCSetUp() and PCApply, both of
> which are getting more expensive as you add processes. These are more
> than 10x more than spent in MatMult() and MatMult() takes slightly
> less time on more processes, so the increase isn't entirely due to
> memory issues.
> What methods are you using?
What do you mean methods? I am doing Cartesian grid 3d CFD, using
fractional mtd which solves the momentum and Poisson eqns. I construct
the linear eqn matrix and insert them in PETSc matrix/vectors. Then I
solve using Bicsstab and hypre AMG respectively. Why is PCSetUp() and
PCApply using more time?
>     However, for the flops, ratios are 1 and 1.1. so which is more
>     important to look at? time or flops?
> If you would rather do a lot of flops than solve the problem in a
> reasonable amount of time, you might as well use dense methods. ;-)
Thanks again!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120109/bee728cb/attachment.htm>
