[petsc-users] GMRES solver
Sat Jan 7 19:39:14 CST 2012
On Jan 7, 2012, at 4:00 PM, Mohamad M. Nasr-Azadani wrote:
> Hi guys,
> I am trying to narrow down an issue with my Poisson solver.
> I have the following problem setup
> Laplace(f) = rhs(x,z,y)
> 0 <= x,y,z <= (Lx,Ly,Lz)
> I solve the Poisson equation in three dimensions with the analytical function f(x,y,z) defined by
> f(x,z,y) = cos(2*pi*x/Lx)*cos(2*pi*y/Ly)*cos(2*pi*z/Lz) + K
> where Lx = Ly =Lz = 1.0 and K is a constant I use to set f(Lx,Ly,Lz) = 0.0.
> Second order descritization is used for the Poisson equation.
> Also, Neumann boundary condition is used everywhere, but I set the top-right-front node's value to zero to get rid of the Nullspaced matrix manually.
   Please don't do this. That results in a unnecessaryly huge condition number. Use KSPSetNullSpace.()
   Also if you are really solving the Poisson problem you should use multigrid; if simple geometry then geometric multigrid if complicated geometry probably easier to use hypre BoomerAMG. No sane person solves Poisson problem with anything but a multigrid or FFT based solver.
   Barry
> I use 20 grid points in each direction.
> The problem is:
> I use GMRES(20) without any preconditioners (rtol = 1e-12) to solve the linear system.
> It takes 77,000 iterations to converge!!!!
> For the size of only 8,000 unknowns, even though the lsys is not preconditioned, I guess that is a LOT of iterations.
> Next, I setup the exact same problem in MATLAB and use their GMRES solver function.
> I set the same parameters and MATLAB tells me that it converges using only 3870 iterations.
> I know that there might be some internal differences between MATLAB and PETSc's implementations of this method, but given the fact that these two solvers are not preconditioned, I am wondering about this big difference?
> Any ideas?
> Best,
> Mohamad
