[petsc-users] Error in VecAssemeblyBegin after VecView
Johannes.Huber at unibas.ch Johannes.Huber at unibas.ch
Fri Jan 6 00:46:53 CST 2012
Quoting Jed Brown <jedbrown at mcs.anl.gov>:
> On Thu, Jan 5, 2012 at 02:39, <Johannes.Huber at unibas.ch> wrote:
>> When I take a look to the valgrind output, I see a few lines about
>> unaddressable bytes. Is this a reason to concern?
> Please paste lines for questions like this.
Here are the lines:
==22507== Unaddressable byte(s) found during client check request
==22507==    at 0x4E34BFD: check_mem_is_defined_untyped (libmpiwrap.c:953)
==22507==    by 0x4E499AA: walk_type (libmpiwrap.c:691)
==22507==    by 0x4E4D7A3: PMPI_Allreduce (libmpiwrap.c:924)
==22507==    by 0x74846D0: MPIR_Get_contextid (in /usr/lib/libmpich.so.1.2)
==22507==    by 0x7484CF1: MPIR_Comm_copy (in /usr/lib/libmpich.so.1.2)
==22507==    by 0x747D280: PMPI_Comm_dup (in /usr/lib/libmpich.so.1.2)
==22507==    by 0x4E48C4A: PMPI_Comm_dup (libmpiwrap.c:2110)
==22507==    by 0x586878D: PetscCommDuplicate (tagm.c:149)
==22507==    by 0x54718AD: PetscHeaderCreate_Private (inherit.c:51)
==22507==    by 0x5891130: VecCreate (veccreate.c:39)
==22507==    by 0x400E3A: main (Test.C:10)
==22507==  Address 0xffffffffffffffff is not stack'd, malloc'd or
(recently) free'd
and
==22508== Unaddressable byte(s) found during client check request
==22508==    at 0x4E34BFD: check_mem_is_defined_untyped (libmpiwrap.c:953)
==22508==    by 0x4E499AA: walk_type (libmpiwrap.c:691)
==22508==    by 0x4E4D7A3: PMPI_Allreduce (libmpiwrap.c:924)
==22508==    by 0x74846D0: MPIR_Get_contextid (in /usr/lib/libmpich.so.1.2)
==22508==    by 0x7484CF1: MPIR_Comm_copy (in /usr/lib/libmpich.so.1.2)
==22508==    by 0x747D280: PMPI_Comm_dup (in /usr/lib/libmpich.so.1.2)
==22508==    by 0x4E48C4A: PMPI_Comm_dup (libmpiwrap.c:2110)
==22508==    by 0x586878D: PetscCommDuplicate (tagm.c:149)
==22508==    by 0x54718AD: PetscHeaderCreate_Private (inherit.c:51)
==22508==    by 0x5891130: VecCreate (veccreate.c:39)
==22508==    by 0x400E3A: main (Test.C:10)
==22508==  Address 0xffffffffffffffff is not stack'd, malloc'd or
(recently) free'd
==22508==
--22508-- REDIR: 0x744f8c0 (PMPI_Attr_put) redirected to 0x4e46b46
(PMPI_Attr_put)
--22508-- REDIR: 0x74df090 (PMPI_Recv) redirected to 0x4e4e4b4 (PMPI_Recv)
==22508== Uninitialised byte(s) found during client check request
==22508==    at 0x4E49738: PMPI_Get_count (libmpiwrap.c:953)
==22508==    by 0x4E4E704: PMPI_Recv (libmpiwrap.c:419)
==22508==    by 0x56BE525: VecView_MPI_ASCII (pdvec.c:78)
==22508==    by 0x56C1BDA: VecView_MPI (pdvec.c:837)
==22508==    by 0x58A9C9D: VecView (vector.c:746)
==22508==    by 0x400EEA: main (Test.C:21)
==22508==  Address 0x7fefffe30 is on thread 1's stack
==22508==  Uninitialised value was created by a stack allocation
==22508==    at 0x56BD490: VecView_MPI_ASCII (pdvec.c:36)
==22508==
==22508==    by 0x56BE57F: VecView_MPI_ASCII (pdvec.c:79)
>> BTW: I also see memory leaks from getpwuid. Does anybody know about a
>> patch for this?
> I think this is a libc issue.
This message was sent using IMP, the Internet Messaging Program.
