[petsc-users] MatGetRowMinAbs returns negative number
Wed Jan 4 17:42:28 CST 2012
On Wed, Jan 4, 2012 at 5:29 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Do you think this issue can potentially explain a behavior I observe:
> In my big block shell matrix there are two blocks submatrices: (say) B
> and B transposed. MaxAbs is exact same for both submatrices, MinAbs is
> zero for B (as expected), but small negative for the other
> (unexpected).
> Now question: do I have a bug (that I do not immediately see) or this
> can be hopefully only a trick in MinAbs?
It was a bug in MinAbs. I am pushing the fix.
   Matt
> Thanks a lot.
> On Wed, Jan 4, 2012 at 6:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > On Wed, Jan 4, 2012 at 11:02, Matthew Knepley <knepley at gmail.com> wrote:
> >> Okay, here is what is wrong with the logic:
> >> 1) Its not a shift, it ignores values < 1.0e-12
> > you wrote that in the commit message
> >> 2) The problem is on line 2.17 of the diff where it takes the first
> value
> >> as minimum, but does not take the absolute value
> > good catch
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120104/1ea7e256/attachment-0001.htm>
