[petsc-users] Configuring without debug
Bojan Niceno bojan.niceno at psi.ch
Tue Feb 28 02:56:08 CST 2012
Sorry for this post, I figured out myself what was I doing wrong.
I was configuring for compilation without debugging, but my PETSC_ARCH
variable was still set to arch-linux2-c-debug :-(
I have the optimized version running as I write this message.
     Cheers,
     Bojan
On 2/28/2012 9:27 AM, Bojan Niceno wrote:
> Dear all,
> I am trying to configure PETSc with*out* debugging.
> I am issuing the following command:
> ./configure --with-mpi-dir=/opt/mpi/openmpi-1.2.6-gcc-4.1
> --with-debugging=0 COPTFLAGS='-O3 -march=p4 -mtune=p4' FOPTFLAGS='-O3
> -qarch=p4 -qtune=p4'.
> The configuration procedure starts well, saying:
> WARNING! Compiling PETSc with no debugging, this should
> only be done for timing and production runs. All development should
> be done when configured using
> --with-debugging=1
> which is is fine, which is what I wanted, but it ends with the message:
> xxx=========================================================================xxx
>  Configure stage complete. Now build PETSc libraries with (legacy build):
>    make PETSC_DIR=/homecfd/niceno/PETSc-3.2-p6-O
> PETSC_ARCH=arch-linux2-c-debug all
> Judging from the proposed PETSC_ARCH, it seems that debugging got
> switched back on :-(
> Then I type make, and, after a while, get the message:
> Completed building libraries
> Now to check if the libraries are working do:
> PETSC_ARCH=arch-linux2-c-debug test
> Is there a way to build PETSc with*out* debugging option?
>     Kind regards,
>     Bojan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/40884f0b/attachment.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/40884f0b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120228/40884f0b/attachment-0001.png>
