[petsc-users] Matrix format mpiaij does not have a built-in PETSc XXX!
Max Rudolph maxwellr at gmail.com
Sun Feb 26 10:48:48 CST 2012
MPIAIJ and SEQQIJ matrices are subtypes of the AIJ matrix type. Looking at
that table, you should be able to use any of the PCs that supports AIJ and
has an X under 'parallel'.
Max
On Sun, Feb 26, 2012 at 8:16 AM, Aron Roland <aaronroland at gmx.de> wrote:
> Dear All,
> I hope somebody can help us on this or give at least some clearance.
> We have just included PETSc as an solver for our sparse matrix evolving
> from an unstructured mesh advection scheme.
> The problem is that we are using the mpiaij matrix type, since our matrix
> is naturally sparse. However it seems that PETSc has no PC for this, except
> the PCSOR, which showed to be not very effective for our problem.
> All others give the error msg. of the mail subject, where XXX are the
> different PC tried.
> The manual is a bit diffuse on this e.g.
> http://www.mcs.anl.gov/petsc/**documentation/**linearsolvertable.html<http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html>
> it is claimed that certain PC's are running on aij matrices ... but these
> are to be defined either as seq. or parallel (mpiaij) matrices. Moreover in
> the above mentioned list are two columns parallel/seriel, what is the
> intention of parallel capability when not applicable to matrices stored
> within the parallel mpiaij framework.
> I guess we just not understanding the concept or have some other
> difficulties of understanding of all this.
> Any comments help is welcome
> Aron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120226/9eca1576/attachment.htm>
