[petsc-users] Important Petsc header files to include
Sat Feb 25 18:50:13 CST 2012
On Sat, Feb 25, 2012 at 6:01 PM, Mengda Wu <wumengda at gmail.com> wrote:
> Hi all,
>     I am trying to select a set of important petsc header files to
> included in my installation of Petsc. Basically, I would like the header
> and library files to be outside of Petsc source directory. I found there
> are many headers under PETSC_DIR/include. Are these all necessary for a
> program to just use PETSC functions?
It sounds like what you want is installation. Configure using
--prefix=<directory> and then 'make; make install'. Everything you
need will be in that directory.
   Matt
> Thanks,
> Mengda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120225/110696b0/attachment.htm>
