[petsc-users] testing scalability for ksp/ex22.c (now ex45.c)
Francis Poulin fpoulin at uwaterloo.ca
Fri Feb 24 21:20:16 CST 2012
Hello Barry,
Thanks for offering to look at this.
I configured a different version that does not have the debugger and the results are a lot faster but the efficiency is still similar.  Below you'll see the results.
n		Tp 		Efficiency
1		162		1
2		110		0.74
4		47		0.86
8		24		0.84
16		12		0.84
32		6		0.84
I'm also including the output of the log_summary for n =1 and 2.
As I said before, this is an SMP machine so I would expect it to be better than the typical cluster.  That being said I am still learning how this works.
I am very happy that I managed to get some encouraging results in a day.
Cheers, Francis
On 2012-02-24, at 9:08 PM, Jed Brown wrote:
> On Fri, Feb 24, 2012 at 14:43, Francis Poulin <fpoulin at uwaterloo.ca> wrote:
> It seems to scale beautifully starting at 2 but there is a big drop from 1 to 2.  I suspect there's a very good reason for this, I just don't know what.
> Can you send the full output? The smoother is slightly different, so the number of iterations could be different by 1 (for example). The -log_summary part of the output will show us where the time is being spent, so we'll be able to say what did not scale well between 1 and 2 procs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/97b22c8a/attachment-0003.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/97b22c8a/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/97b22c8a/attachment-0004.htm>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/97b22c8a/attachment-0003.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/97b22c8a/attachment-0005.htm>
