[petsc-users] Accessing Vector's ghost values
Bojan Niceno bojan.niceno at psi.ch
Thu Feb 23 17:18:39 CST 2012
On 2/23/2012 11:49 PM, Mohammad Mirzadeh wrote:
> based on,
> VecCreateGhost(PETSC_COMM_WORLD, n, PETSC_DECIDE, nghost, &ghosts[0], &x);
> it seems to me that x is your actual ghosted vector. If this is true,
> then you need to get its "local" form via VecGhostGetLocalForm
> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGhostGetLocalForm.html#VecGhostGetLocalForm>().
> Once you have done, you should be able to access the ghosted nodes.
> Are you calling this function anywhere?
I tried that before.  I did:
Vec lx;
VecGhostGetLocalForm(x, &lx)
then I copied "lx" to my variable, like
for(Int i=1; i<N; i++)    /* N includes buffer cells */
   unk[i] = lx[i]
but ghost values were also zero.   I am thinking that PETSc somehow
clears the ghost values after a call to KSP.  Is it the case?
     Kind regards,
     Bojan
> On Thu, Feb 23, 2012 at 2:32 PM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
>     Dear Mohammad,
>     it doesn't help me, or I did not understand your explanation.
>     If I do this:
>       /* copy internal values (THIS WORKS, BUT COPIES NO BUFFER
>     VALUES) */
>       for(Int i=0; i<n; i++) {
>         Int gi = mesh.nodes[i].global_number;
>         VecGetValues(x, 1, &gi, &unk[i]);
>       /* copy ghost values (CREATES MANY WARNINGS */
>       for(Int i=n; i<N; i++) {
>         VecGetValues(x, 1, &i, &unk[i]);
>     I get arnings are like this.
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Argument out of range!
>     [0]PETSC ERROR: Can only get local values, trying 3518!
>     [3]PETSC ERROR: --------------------- Error Message
>     [3]PETSC ERROR: Argument out of range!
>     [3]PETSC ERROR: Can only get local values, trying 3511!
>     [3]PETSC ERROR:
>     What am I doing wrong here?
>         Cheers,
>         Bojan
>     On 2/23/2012 11:23 PM, Mohammad Mirzadeh wrote:
>>     just index x with the local numberings. if you have 'n' local
>>     nodes and 'g' ghost nodes in x, ghost nodes indecies run from 'n'
>>     to 'n+g-1'
>>     On Feb 23, 2012 1:16 PM, "Bojan Niceno" <bojan.niceno at psi.ch
>>         Dear Jed,
>>         thanks.
>>         Now I have the following:
>>         - Array unk, which should hold values inside the partition
>>         and in ghost cells.  It is big enough to hold both
>>         - Vec x, created by command VecCreateGhost, with proper
>>         padding for ghost cells
>>         - Successful call to linear solver in parallel.
>>         But I need to copy ghost values from x to my array unk.
>>         How can I do it?
>>             Kind regards,
>>             Bojan
>>         On 2/23/2012 10:10 PM, Jed Brown wrote:
>>>         On Thu, Feb 23, 2012 at 15:05, Bojan Niceno
>>>         <bojan.niceno at psi.ch <mailto:bojan.niceno at psi.ch>> wrote:
>>>             No, I use global.
>>>         The local form is just a local vector. It doesn't even know
>>>         that a global problem exists. You can't index into it using
>>>         global indices. (In general, there is no efficient way to
>>>         look up information in the local vector (includes ghost
>>>         points) using global indices.)
>>>             "n" is defined as the number of cells inside, i.e.
>>>             without buffers.  "unk" is my external array.  If I try
>>>             to access buffer values, I use:
>>>               for(Int i=0; i<N; i++) {
>>>             But then I end up with tons of warnings, presumably
>>>             because I am going beyond "n".  Vector x was created
>>>             with VecCreateGhost.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/43b62b50/attachment-0001.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/43b62b50/attachment-0003.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/43b62b50/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120224/43b62b50/attachment-0005.png>
