[petsc-users] Accessing Vector's ghost values
Bojan Niceno bojan.niceno at psi.ch
Thu Feb 23 15:05:14 CST 2012
No, I use global.
   for(Int i=0; i<n; i++) {
     Int gi = mesh.nodes[i].global_number;
     VecGetValues(x, 1, &gi, &unk[i]);
"n" is defined as the number of cells inside, i.e. without buffers.
"unk" is my external array.  If I try to access buffer values, I use:
   for(Int i=0; i<N; i++) {
But then I end up with tons of warnings, presumably because I am going
beyond "n".  Vector x was created with VecCreateGhost.
On 2/23/2012 10:00 PM, Mohammad Mirzadeh wrote:
> Are you using local numbering when accessing the local part of ghost
> nodes?
> On Thu, Feb 23, 2012 at 12:43 PM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
>     Dear Matt,
>     I have a new insight, although is not the full resolution.  If I
>     change my code in PETScSolver.cpp from:
>       |  Make necessary PETSc intializations for vetors  |
>       Int   nghost = N - n;
>       Int * ghosts = new Int(nghost);
>       for(Int n=0; n<M.mesh.nodes.size(); n++) {
>         assert( M.mesh.nodes[n].global_number >= 0);
>         assert( M.mesh.nodes[n].global_number < 14065);
>       for(Int i=n; i<N; i++) {
>         assert( M.mesh.nodes[i].global_number >= 0);
>         assert( M.mesh.nodes[i].global_number < 14065);
>         assert( ! (M.mesh.nodes[i].global_number >= n_start &&
>                    M.mesh.nodes[i].global_number <  n_end) );
>           ghosts[i] = M.mesh.nodes[i].global_number;
>       VecCreateGhost(PETSC_COMM_WORLD, n, PETSC_DECIDE, nghost,
>     &ghosts[0], &x);
>     to:
>       Int     nghost = N - n;
>       Indices ghosts;                                         // <---=
>     NEW!
>           ghosts.push_back( M.mesh.nodes[i].global_number );  // <---=
>     NEW!
>       assert( ghosts.size() == nghost ); // <---= NEW!
>     &ghosts[0], &x);
>     I pass the VecCreateGhost phase.  "Indices" is an STL container of
>     integers.  It seems it works better than classical C array for
>     this case.
>     However, I still do not see the ghost values, i.e. I get the
>     following error:
>     [1]PETSC ERROR: --------------------- Error Message
>     [1]PETSC ERROR: [0]PETSC ERROR: --------------------- Error
>     Message ------------------------------------
>     [0]PETSC ERROR: Argument out of range!
>     [0]PETSC ERROR: Can only get local values, trying 3529!
>     [0]PETSC ERROR:
>     [1]PETSC ERROR: Can only get local values, trying 22!
>     [1]PETSC ERROR:
>     [1]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
>     09:28:45 CST 2012
>     [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [1]PETSC ERROR: See docs/index.html for manual pages.
>     [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error
>     [2]PETSC ERROR: Argument out of range!
>     [2]PETSC ERROR: Can only get local values, trying 86!
>     [2]PETSC ERROR:
>     [2]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6, Wed Jan 11
>     09:28:45 CST 2012
>     when I am trying to access values in ghost cells.  What do I have
>     to use to see them ghosts?  I reckon VecGhostGetLocalForm should
>     be used, right?
>         Kind regards,
>         Bojan
>     On 2/23/2012 8:36 PM, Matthew Knepley wrote:
>>     On Thu, Feb 23, 2012 at 1:33 PM, Bojan Niceno
>>     <bojan.niceno at psi.ch <mailto:bojan.niceno at psi.ch>> wrote:
>>         Dear Matt,
>>         I sent the code as an attached tarball.  I sent it with case
>>         I run, so is 2 MB big.  It is now in the cue for moderator's
>>         approval.
>>     No, you HAVE to send it to petsc-maint at mcs.anl.gov
>>     <mailto:petsc-maint at mcs.anl.gov>, as I said last time, for
>>     exactly this reason.
>>       Matt
>>         Thanks.
>>             Kind regards,
>>             Bojan
>>         On 2/23/2012 8:04 PM, Matthew Knepley wrote:
>>>         On Thu, Feb 23, 2012 at 12:51 PM, Bojan Niceno
>>>             Dear Matt,
>>>             are you sure?  It is almost 4000 lines long!  Shall I
>>>             send only the function which bother me?
>>>             If the entire code is what you need, shall I make a
>>>             tarball and attach it?
>>>         Send something the builds and runs. Don't care how long it is.
>>>            Matt
>>>                 Kind regards,
>>>                 Bojan
>>>             On 2/23/2012 7:44 PM, Matthew Knepley wrote:
>>>>             On Thu, Feb 23, 2012 at 12:28 PM, Bojan Niceno
>>>>                 On 2/23/2012 7:24 PM, Matthew Knepley wrote:
>>>>>                 On Thu, Feb 23, 2012 at 12:05 PM, Bojan Niceno
>>>>>                 wrote:
>>>>>                     Dear Matthew,
>>>>>                     thank you for your response.  When I use
>>>>>                     VecCreateGhost, I get the following:
>>>>>                 It appears that you passed a bad communicator. Did
>>>>>                 you not initialize a 'comm' variable?
>>>>                 I pass PETSC_COMM_WORLD to VecCreateGhost.
>>>>                 I don't know what you mean by 'comm' variable :-(
>>>>                 I called all the routines to initialize PETSc.
>>>>             Send your code to petsc-maint at mcs.anl.gov
>>>>             <mailto:petsc-maint at mcs.anl.gov>.
>>>>                Matt
>>>>                     Cheers,
>>>>                     Bojan
>>>>>                    Matt
>>>>>                     [0]PETSC ERROR:
>>>>>                     [0]PETSC ERROR: Caught signal number 11 SEGV:
>>>>>                     Segmentation Violation, probably memory access
>>>>>                     out of range
>>>>>                     [0]PETSC ERROR: Try option -start_in_debugger
>>>>>                     or -on_error_attach_debugger
>>>>>                     [0]PETSC ERROR: or see
>>>>>                     http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
>>>>>                     ERROR: or try http://valgrind.org on GNU/linux
>>>>>                     and Apple Mac OS X to find memory corruption
>>>>>                     errors
>>>>>                     [0]PETSC ERROR: likely location of problem
>>>>>                     given in stack below
>>>>>                     [0]PETSC ERROR: ---------------------  Stack
>>>>>                     Frames ------------------------------------
>>>>>                     [0]PETSC ERROR: Note: The EXACT line numbers
>>>>>                     in the stack are not available,
>>>>>                     [0]PETSC ERROR:       INSTEAD the line number
>>>>>                     of the start of the function
>>>>>                     [0]PETSC ERROR:       is given.
>>>>>                     [0]PETSC ERROR: [0] PetscCommDuplicate line
>>>>>                     140 src/sys/objects/tagm.c
>>>>>                     [0]PETSC ERROR: [0] PetscHeaderCreate_Private
>>>>>                     line 30 src/sys/objects/inherit.c
>>>>>                     [0]PETSC ERROR: [0] VecCreate line 32
>>>>>                     src/vec/vec/interface/veccreate.c
>>>>>                     [0]PETSC ERROR: [0] VecCreateGhostWithArray
>>>>>                     line 567 src/vec/vec/impls/mpi/pbvec.c
>>>>>                     [0]PETSC ERROR: [0] VecCreateGhost line 647
>>>>>                     [0]PETSC ERROR: Signal received!
>>>>>                     [0]PETSC ERROR:
>>>>>                     [0]PETSC ERROR: Petsc Release Version 3.2.0,
>>>>>                     Patch 6, Wed Jan 11 09:28:45 CST 2012
>>>>>                     [0]PETSC ERROR: See docs/changes/index.html
>>>>>                     for recent updates.
>>>>>                     [0]PETSC ERROR: See docs/faq.html for hints
>>>>>                     [0]PETSC ERROR: See docs/index.html for manual
>>>>>                     pages.
>>>>>                     [0]PETSC ERROR:
>>>>>                     [0]PETSC ERROR: ./PSI-Flow on a arch-linu
>>>>>                     named lccfd06 by niceno Thu Feb 23 19:02:45 2012
>>>>>                     [0]PETSC ERROR: Libraries linked from
>>>>>                     /homecfd/niceno/PETSc-3.2-p6/arch-linux2-c-debug/lib
>>>>>                     [0]PETSC ERROR: Configure run at Fri Feb 10
>>>>>                     10:24:13 2012
>>>>>                     [0]PETSC ERROR: Configure options
>>>>>                     [0]PETSC ERROR:
>>>>>                     [0]PETSC ERROR: User provided function() line
>>>>>                     0 in unknown directory unknown file
>>>>>                     I don't understand what could be causing it.
>>>>>                     I took very good care to match the global
>>>>>                     numbers of ghost cells when calling VecCreateGhost
>>>>>                         Kind regards,
>>>>>                         Bojan
>>>>>                     On 2/23/2012 5:53 PM, Matthew Knepley wrote:
>>>>>>                     On Thu, Feb 23, 2012 at 10:46 AM, Bojan
>>>>>>                         Hi all,
>>>>>>                         I've never used a mailing list before, so
>>>>>>                         I hope this message will reach PETSc
>>>>>>                         users and experts and someone might be
>>>>>>                         willing to help me.  I am also novice in
>>>>>>                         PETSc.
>>>>>>                         I have developed an unstructured finite
>>>>>>                         volume solver on top of PETSc libraries.
>>>>>>                          In sequential, it works like a charm.
>>>>>>                          For the parallel version, I do domain
>>>>>>                         decomposition externally with Metis, and
>>>>>>                         work out local and global numberings, as
>>>>>>                         well as communication patterns between
>>>>>>                         processor.  (The latter don't seem to be
>>>>>>                         needed for PETSc, though.)  When I run my
>>>>>>                         program in parallel, it also works, but I
>>>>>>                         miss values in vectors' ghost points.
>>>>>>                         I create vectors with command:
>>>>>>                         VecCreate(PETSC_COMM_WORLD, &x);
>>>>>>                         Is it possible to get the ghost values if
>>>>>>                         a vector is created like this?
>>>>>>                     I do not understand this question. By
>>>>>>                     definition, "ghost values" are those not
>>>>>>                     stored in the global vector.
>>>>>>                         I have tried to use VecCreateGhost, but
>>>>>>                         for some reason which is beyond my
>>>>>>                         comprehension, PETSc goes berserk when it
>>>>>>                         reaches the command:
>>>>>>                         PETSC_DECIDE, nghost, ifrom, &x)
>>>>>>                     I think you can understand that "berserk"
>>>>>>                     tells me absolutely nothing. Error message?
>>>>>>                     Stack trace? Did you try to run an
>>>>>>                     example which uses VecGhost?
>>>>>>                       Thanks,
>>>>>>                          Matt
>>>>>>                         Can anyone help me?  Either how to reach
>>>>>>                         ghost values for vector created by
>>>>>>                         VecCreate, or how to use VecCreateGhost
>>>>>>                         properly?
>>>>>>                           Kind regards,
>>>>>>                           Bojan
>>>>>>                     What most experimenters take for granted
>>>>>>                     before they begin their experiments is
>>>>>>                     infinitely more interesting than any results
>>>>>>                     to which their experiments lead.
>>>>>>                     -- Norbert Wiener
>>>>>                 What most experimenters take for granted before
>>>>>                 they begin their experiments is infinitely more
>>>>>                 interesting than any results to which their
>>>>>                 experiments lead.
>>>>>                 -- Norbert Wiener
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0001.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0006.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0007.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0008.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0009.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/928a0168/attachment-0011.png>
