[petsc-users] testing scalability for ksp/ex22.c
Thu Feb 23 14:27:29 CST 2012
Always send output with -log_summary for each run that you do.
On Thu, Feb 23, 2012 at 14:16, Francis Poulin <fpoulin at uwaterloo.ca> wrote:
> Hello,
> I am learning to use PetSc but am just a notice.  I have a rather basic
> question to ask and couldn't not find it on the achieves.
> I am wanting to test the scalability of a Multigrid solver to the 3D
> Poisson equation.  I found ksp/ex22.c that seems to solve the problem that
> I'm interested in.  I ran it on a large server using different processors.
> The syntax that I use to run using MPI was
> ./ex22 -da_grid_x 64 -da_grid_y 64 -da_grid_z 32
Which version of PETSc?
> I tested it using 2, 4, 8, 16 cpus and found that the time increases.  See
> below.  Clearly there is something that I don't understand since the time
> should be reduced.
> n               wtime
> 2               3m58s
> 4               3m54s
> 8               5m51s
> 16              7m23s
> Any advice would be greatly appreciated.
> Best regrads,
> Francis
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/9bbe559b/attachment.htm>
