[petsc-users] Accessing Vector's ghost values
Bojan Niceno bojan.niceno at psi.ch
Thu Feb 23 13:33:19 CST 2012
Dear Matt,
I sent the code as an attached tarball.  I sent it with case I run, so
is 2 MB big.  It is now in the cue for moderator's approval.
Thanks.
     Kind regards,
     Bojan
On 2/23/2012 8:04 PM, Matthew Knepley wrote:
> On Thu, Feb 23, 2012 at 12:51 PM, Bojan Niceno <bojan.niceno at psi.ch
> <mailto:bojan.niceno at psi.ch>> wrote:
>     Dear Matt,
>     are you sure?  It is almost 4000 lines long!  Shall I send only
>     the function which bother me?
>     If the entire code is what you need, shall I make a tarball and
>     attach it?
> Send something the builds and runs. Don't care how long it is.
>    Matt
>         Kind regards,
>         Bojan
>     On 2/23/2012 7:44 PM, Matthew Knepley wrote:
>>     On Thu, Feb 23, 2012 at 12:28 PM, Bojan Niceno
>>     <bojan.niceno at psi.ch <mailto:bojan.niceno at psi.ch>> wrote:
>>         On 2/23/2012 7:24 PM, Matthew Knepley wrote:
>>>         On Thu, Feb 23, 2012 at 12:05 PM, Bojan Niceno
>>>             Dear Matthew,
>>>             thank you for your response.  When I use VecCreateGhost,
>>>             I get the following:
>>>         It appears that you passed a bad communicator. Did you not
>>>         initialize a 'comm' variable?
>>         I pass PETSC_COMM_WORLD to VecCreateGhost.
>>         I don't know what you mean by 'comm' variable :-(  I called
>>         all the routines to initialize PETSc.
>>     Send your code to petsc-maint at mcs.anl.gov
>>     <mailto:petsc-maint at mcs.anl.gov>.
>>        Matt
>>             Cheers,
>>             Bojan
>>>            Matt
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: Caught signal number 11 SEGV:
>>>             Segmentation Violation, probably memory access out of range
>>>             [0]PETSC ERROR: Try option -start_in_debugger or
>>>             -on_error_attach_debugger
>>>             [0]PETSC ERROR: or see
>>>             http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
>>>             ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>             Mac OS X to find memory corruption errors
>>>             [0]PETSC ERROR: likely location of problem given in
>>>             stack below
>>>             [0]PETSC ERROR: ---------------------  Stack Frames
>>>             [0]PETSC ERROR: Note: The EXACT line numbers in the
>>>             stack are not available,
>>>             [0]PETSC ERROR:       INSTEAD the line number of the
>>>             start of the function
>>>             [0]PETSC ERROR:       is given.
>>>             [0]PETSC ERROR: [0] PetscCommDuplicate line 140
>>>             src/sys/objects/tagm.c
>>>             [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 30
>>>             src/sys/objects/inherit.c
>>>             [0]PETSC ERROR: [0] VecCreate line 32
>>>             src/vec/vec/interface/veccreate.c
>>>             [0]PETSC ERROR: [0] VecCreateGhostWithArray line 567
>>>             src/vec/vec/impls/mpi/pbvec.c
>>>             [0]PETSC ERROR: [0] VecCreateGhost line 647
>>>             [0]PETSC ERROR: --------------------- Error Message
>>>             [0]PETSC ERROR: Signal received!
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 6,
>>>             Wed Jan 11 09:28:45 CST 2012
>>>             [0]PETSC ERROR: See docs/changes/index.html for recent
>>>             updates.
>>>             [0]PETSC ERROR: See docs/faq.html for hints about
>>>             trouble shooting.
>>>             [0]PETSC ERROR: See docs/index.html for manual pages.
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: ./PSI-Flow on a arch-linu named lccfd06
>>>             by niceno Thu Feb 23 19:02:45 2012
>>>             [0]PETSC ERROR: Libraries linked from
>>>             /homecfd/niceno/PETSc-3.2-p6/arch-linux2-c-debug/lib
>>>             [0]PETSC ERROR: Configure run at Fri Feb 10 10:24:13 2012
>>>             [0]PETSC ERROR: Configure options
>>>             [0]PETSC ERROR:
>>>             [0]PETSC ERROR: User provided function() line 0 in
>>>             unknown directory unknown file
>>>             I don't understand what could be causing it.  I took
>>>             very good care to match the global numbers of ghost
>>>             cells when calling VecCreateGhost
>>>                 Kind regards,
>>>                 Bojan
>>>             On 2/23/2012 5:53 PM, Matthew Knepley wrote:
>>>>             On Thu, Feb 23, 2012 at 10:46 AM, Bojan Niceno
>>>>                 Hi all,
>>>>                 I've never used a mailing list before, so I hope
>>>>                 this message will reach PETSc users and experts and
>>>>                 someone might be willing to help me.  I am also
>>>>                 novice in PETSc.
>>>>                 I have developed an unstructured finite volume
>>>>                 solver on top of PETSc libraries.  In sequential,
>>>>                 it works like a charm.  For the parallel version, I
>>>>                 do domain decomposition externally with Metis, and
>>>>                 work out local and global numberings, as well as
>>>>                 communication patterns between processor.  (The
>>>>                 latter don't seem to be needed for PETSc, though.)
>>>>                  When I run my program in parallel, it also works,
>>>>                 but I miss values in vectors' ghost points.
>>>>                 I create vectors with command:
>>>>                 VecCreate(PETSC_COMM_WORLD, &x);
>>>>                 Is it possible to get the ghost values if a vector
>>>>                 is created like this?
>>>>             I do not understand this question. By definition,
>>>>             "ghost values" are those not stored in the global vector.
>>>>                 I have tried to use VecCreateGhost, but for some
>>>>                 reason which is beyond my comprehension, PETSc goes
>>>>                 berserk when it reaches the command:
>>>>                 VecCreateGhost(PETSC_COMM_WORLD, n, PETSC_DECIDE,
>>>>                 nghost, ifrom, &x)
>>>>             I think you can understand that "berserk" tells me
>>>>             absolutely nothing. Error message? Stack trace? Did you
>>>>             try to run an
>>>>             example which uses VecGhost?
>>>>               Thanks,
>>>>                  Matt
>>>>                 Can anyone help me?  Either how to reach ghost
>>>>                 values for vector created by VecCreate, or how to
>>>>                 use VecCreateGhost properly?
>>>>                   Kind regards,
>>>>                   Bojan
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/0fdd283d/attachment-0001.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/0fdd283d/attachment-0004.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/0fdd283d/attachment-0005.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/0fdd283d/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120223/0fdd283d/attachment-0007.png>
