[petsc-users] Add a matrix to MatNest twice
Tue Feb 21 08:09:03 CST 2012
On Tue, Feb 21, 2012 at 07:43, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Seems not to work correctly. I made some small changes in
> src/ksp/ksp/examples/tests/ex22.c:
> 21c21
> <   np = 2;
> >   np = 3;
> 62c62
> <   tmp[0][0] = A11;
> >   tmp[0][0] = A12;
> When running with 2 threads, it ends with a segmentation violation. The
> stack is as follows:
> [0]PETSC ERROR: [0] MatStashScatterEnd_Private line 109
> src/mat/utils/matstash.c
> [0]PETSC ERROR: [0] MatAssemblyEnd_MPIAIJ line 641
> src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: [0] MatAssemblyEnd line 4934 src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] MatAssemblyEnd_Nest line 228
> src/mat/impls/nest/matnest.c
> [0]PETSC ERROR: [0] test_solve line 17 src/ksp/ksp/examples/tests/ex22.c
Okay, the problem is that MatAssemblyBegin and MatAssemblyEnd are called
twice on the same matrix. There are two ways to fix this:
1. Add a flag to Mat so we can tell when a matrix is being assembled. This
makes it so we can't error if an external user leaves a MatAssemblyBegin()
open with no closing MatAssemblyEnd().
2. Uniquify a list of non-empty mats so we only call it once. This doesn't
work because you could have nested MatNests:
[[A 0;0 B] 0; 0 A]
I'm in the midst of something right now, but I'll get back to this if
nobody beats me to it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120221/81b6e6d8/attachment.htm>
