[petsc-users] petsc-users Digest, Vol 38, Issue 41
coco at dmi.unict.it coco at dmi.unict.it
Fri Feb 17 13:09:59 CST 2012
Thank you for the answer.
> Date: Fri, 17 Feb 2012 10:11:51 -0600
> From: Matthew Knepley <knepley at gmail.com>
> Subject: Re: [petsc-users] Multigrid as a preconditioner
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> 	<CAMYG4GkKE6doSQ1FgHCSr1deZRYS0kpvLQF8daqv0au==tOgyw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> On Fri, Feb 17, 2012 at 6:38 AM, <coco at dmi.unict.it> wrote:
>> Thank you very much for the answer, but some other doubts remain.
>> Date: Thu, 16 Feb 2012 13:39:11 -0600
>>> Message-ID:
>>>       <CAMYG4Gmt_mn_**hPVKOrbC452geco3Zz26SF05pGy6t7**
>>> RPAq+0Zg at mail.gmail.com<CAMYG4Gmt_mn_hPVKOrbC452geco3Zz26SF05pGy6t7RPAq%2B0Zg at mail.gmail.com>
>>> On Thu, Feb 16, 2012 at 12:54 PM, <coco at dmi.unict.it> wrote:
>>> Dear list,
>>>> I would like to parallelize a multigrid code by Petsc. I do not want to
>>>> use the DMMG infrastructure, since it will be replaced in the next PETSc
>>>> release. Therefore I preferred to use the multigrid as a preconditioner.
>>>> In
>>>> practice, I use the Richardson iteration, choosing the same matrix of the
>>>> linear system as a preconditioner, so that I think the Richardson
>>>> iteration
>>>> should converge in only one iteration, and effectively it is like solving
>>>> the whole linear system by the multigrid.
>>> Your understanding of the Richardson iteration is flawed. You can consult
>>> Yousef Saad's book for the standard definition and anaysis.
>> I think my explanation was not so clear. What I would like to do is to use
>> a preconditioned Richardson iteration:
>> x^(n+1) = x^n + P^(-1) (f-A x^n)
>> Choosing P=A, I should expect to obtain the exact solution at the first
>> iteration. Then, the whole linear system is solved by the preconditioner
>> method that I chose. Is it what Petsc would do?
> I am not sure what you mean by "Is it what Petsc would do?". PETSc does
> what you tell it to do. If you want it
> to solve in one iteration, tell it to use LU, -ksp_type richardson -pc_type
> lu.
Indeed I would like to solve the whole linear system by a multigrid
approach and not by a lu factorization. Therefore I would like to use
-ksp_type richardson -pc_type mg.
In this case, the preconditioned problem P^(-1) (f-A x^n) is solved
exactly or it performs just a V-cycle iteration? In both cases, since
I am using a one-grid multigrid (just for debugging), it should anyway
provide the exact solution at the first iteration, but it is not so.
>>> As a first test, I tried to use a one-grid multigrid (then not a truly
>>>> multigrid). I just set the coarse solver (by a standard KSPSolve), and it
>>>> should be enough, because the multigrid starts already from the coarsest
>>>> grid and then it does not need the smoother and the transfer operators.
>>>> Unfortunately, the iteration scheme (which should be the Richardson
>>>> scheme) converges with a reason=4 (KSP_CONVERGED_ITS) to a wrong
>>>> solution.
>>>> On the other hand, if I solve the whole problem with the standard
>>>> KSPSolve
>>>> (then withouth setting the multigrid as a preconditioner ...), it
>>>> converges
>>>> to the right solution with a reason=2.
>>> Yes, give Richardson many more iterations, -ksp_max_it.
>>>  Matt
>> I tried, but unfortunately nothing changed.
>> Another strange phenomen is that, even with the standard KSP solver (which
>> provides the right solution), if I use the flag -ksp_monitor, nothing is
>> displayed. Is that an indicator of some troubles?
> 1) You must call KSPSetFromOptions() to use command line options
> 2) Run with -ksp_monitor -ksp_view and send the results, or there is no way
> we can know what is happening.
>   Matt
Thank you. I plotted the residual and it decreases so much slowly. It
seems like it is using the non-preconditioned Richardson iteration
x^(n+1) = x^n + P^(-1) (f-A x^n) with P=I instead of P=A.
Thank you.
Armando
>> Thank you in advance.
>> Armando
>>> I thought that the two methods should be the exactly the same method, and
>>>> I do not understand why they provide different convergence results.
>>>> Here is the relevant code:
>>>> // Set the matrix of the linear system
>>>> Mat Mcc;
>>>> ierr=MatCreate(PETSC_COMM_****WORLD,&Mcc); CHKERRQ(ierr);
>>>> ierr=MatSetType(Mcc, MATMPIAIJ); CHKERRQ(ierr);
>>>> ierr=MatSetSizes(Mcc,PETSC_****DECIDE,PETSC_DECIDE,1000,1000)****;
>>>> CHKERRQ(ierr);
>>>> ierr=setMatrix(Mcc); //It is a routine that set the values of the matrix
>>>> Mcc
>>>> // Set the ksp solver with the multigrid as a preconditioner
>>>> KSP ksp, KspSolver;
>>>> ierr = KSPCreate(PETSC_COMM_WORLD,&****ksp);CHKERRQ(ierr);
>>>> ierr = KSPSetType(ksp,KSPRICHARDSON);
>>>> ierr = KSPGetPC(ksp,&pc);CHKERRQ(****ierr);
>>>> ierr = PCSetType(pc,PCMG);CHKERRQ(****ierr);
>>>> ierr = PCMGSetLevels(pc,1,&PETSC_****COMM_WORLD);CHKERRQ(ierr);
>>>> ierr = PCMGSetType(pc,PC_MG_****MULTIPLICATIVE);CHKERRQ(ierr);
>>>> ierr = PCMGGetCoarseSolve(pc,&****kspCoarseSolve);CHKERRQ(ierr);
>>>> ierr = KSPSetOperators(****kspCoarseSolve,Mcc,Mcc,**
>>>> DIFFERENT_NONZERO_PATTERN);****CHKERRQ(ierr);
>>>> ierr = KSPSetTolerances(****kspCoarseSolve,1.e-12,PETSC_**
>>>> DEFAULT,PETSC_DEFAULT,PETSC_****DEFAULT);CHKERRQ(ierr);
>>>> ierr = KSPSetOperators(ksp,Mcc,Mcc,****DIFFERENT_NONZERO_PATTERN);**
>>>> CHKERRQ(ierr);
>>>> ierr = KSPSetTolerances(ksp,1.e-12,****PETSC_DEFAULT,PETSC_DEFAULT,**
>>>> PETSC_DEFAULT);CHKERRQ(ierr);
>>>> ierr = KSPSolve(ksp,RHS,U);CHKERRQ(****ierr);
>>>> // Solve with the standard KSPSolve
>>>> KSP ksp1;
>>>> ierr = KSPCreate(PETSC_COMM_WORLD,&****ksp1);CHKERRQ(ierr);
>>>> ierr = KSPSetOperators(ksp1,Mcc,Mcc,****DIFFERENT_NONZERO_PATTERN);**
>>>> CHKERRQ(ierr);
>>>> ierr = KSPSetTolerances(ksp1,1.e-12/(****2*nn123),PETSC_DEFAULT,**
>>>> PETSC_**
>>>> DEFAULT,PETSC_DEFAULT);****CHKERRQ(ierr);
>>>> ierr = KSPSolve(ksp1,RHS,U1);CHKERRQ(****ierr);
>>>> At the end, the Vector U and U1 are different.
>>>> Thank you.
>>>> Best regards,
>>>> Armando
