[petsc-users] What do with singular blocks in block matrix preconditioning?
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri Feb 17 05:54:17 CST 2012
Maybe some related question: Most textbooks write that the compatibility
condition to solve a system with constant null space is that the right
hand side has zero mean value. Today I read part of the Multigrid-book
written by Trottenberg, and there the condition is written in a
different form (eq 5.6.22 on page 185): the integral of the right hand
side must be equal on the whole domain and on the boundary. Does any of
you have an explanation for this condition? Is there a book/paper that
considers the compatibility condition in more details?
Thomas
Am 16.02.2012 12:49, schrieb Thomas Witkowski:
> I consider a 2x2 block matrix (saddle point) with the left upper block
> being singular due to Neumann boundary conditions. The whole block
> matrix is still non-singular. I worked on some ideas for block
> preconditioning, but there is always some problem with the singular
> block. All publications I know assume the block to be definite. There
> is also some work on highly  singular blocks, but this is here not the
> case. Does some of you know papers about block preconditioners for
> some class of 2x2 saddle point problems, where the left upper block is
> assumed to be positive semi-definite?
> From a more practical point of view, I have the problem that,
> independently of a special kind of block preconditioner, one has
> always to solve (or to approximate the solution) a system with the
> singular block with an arbitrary right hand side. But in general the
> right hand side does not fulfill the compatibility condition of having
> zero mean. Is there a way out of this problem?
> Thomas
