[petsc-users] ParMETIS_V3_PartGeomKway
Mohammad Mirzadeh mirzadeh at gmail.com
Thu Feb 16 18:14:19 CST 2012
Thanks Mark. It is true that partitioning is NP-complete but its a bit
strange to get result worse than initial numbering. I mean you could at the
very least always compare against initial numbering and if its worse just
use that one!  I think that's what I'm gonna add to my own code then.
Anyways, as long as its a not a bug in my code, i'm happy.
Thanks for the help
On Thu, Feb 16, 2012 at 4:03 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Feb 16, 2012, at 5:06 PM, Mohammad Mirzadeh wrote:
> Thanks everyone for participating in the discussion. I really appreciate
> it. I guess I'm gonna describe the problem more in details here. So
> basically I use parmetis to partition my quadtree grid (we have previously
> talked about why i'm not using p4est right now). Please see figures for a
> sample amr quadtree grid.
> For most cases, the partition quality that I get is reasonable like the
> one for the smaller grid (maximum level of amr = 4) where I have
> color-coded the grid points according to their proc_id (0, 1, 2 and 3) ,
> both before and after the partitioning. In this case, the program tells me
> that:
> [0] # of edge cuts: 35
> [1] # of edge cuts: 35
> [2] # of edge cuts: 35
> [3] # of edge cuts: 35
> [0] Before: # of ghost Nodes: 35
> [1] Before: # of ghost Nodes:  29
> [2] Before: # of ghost Nodes:  35
> [3] Before: # of ghost Nodes:  23
> [0] After: # of ghost Nodes:  17
> [1] After: # of ghost Nodes:  20
> [2] After: # of ghost Nodes:  17
> [3] After: # of ghost Nodes:  16
> Now, the partitioning is quite good and number of ghost points required
> have been dropped after partitioning is applied. However, if i run the code
> for a larger grid (maximum amr level = 8), the partitioning that I get is
> actually worse than the initial numbering i started with (well at least for
> proc 0, 1, 2)
> [0] # of edge cuts: 67
> [1] # of edge cuts: 67
> [2] # of edge cuts: 67
> [3] # of edge cuts: 67
> [0] Before: # of ghost Nodes:  58
> [1] Before: # of ghost Nodes:  67
> [2] Before: # of ghost Nodes:  62
> [3] Before: # of ghost Nodes:  44
> [0] After: # of ghost Nodes:  103
> [1] After: # of ghost Nodes:  115
> [2] After: # of ghost Nodes:  81
> [3] After: # of ghost Nodes:  28
> as you can see for proc 0, 1, and 2 the number of required ghost points
> have been doubled which means more communication. To me, this should not
> happen (maybe i'm wrong here?).
> Partitioning is an NP-something problem, ie, you do not get the optimal
> solution in reasonable time.  If you give ParMetis the optimal initial
> partitioning it will ignore it and just run its algorithm and give you, in
> general, a sub-optimal solution.  It does not check that the initial
> partition was better than what it produced.  So you _can_ get a worse
> partitioning out of ParMetis then what you gave it.
> Mark
> That's why i asked if minimizing edge cuts does not translate to having
> fewer ghost points.
> Does minimizing latency favors creating 'clustered chunks' of points for
> each processor and if so, could that create a partitioning with more ghost
> points?
> One final point, I'm not sure how parmetis is calculating the edge cuts,
> but if you simply count the number of cuts in the smaller graphs, you don't
> get the reported numbers. why is that? (for instance proc 3, cuts 20 edges,
> including extra 'diagonal' ones at the coarse-fine interfaces but parmetis
> reports 35-- i can explain this more in details if needed)
> thanks,
> Mohammad
> On Thu, Feb 16, 2012 at 6:21 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> On Feb 16, 2012, at 8:46 AM, Matthew Knepley wrote:
>> On Thu, Feb 16, 2012 at 7:43 AM, Gerard Gorman <g.gorman at imperial.ac.uk>wrote:
>>> Matthew Knepley emailed the following on 16/02/12 13:29:
>>> > On Thu, Feb 16, 2012 at 3:38 AM, Mohammad Mirzadeh <mirzadeh at gmail.com
>>> > <mailto:mirzadeh at gmail.com>> wrote:
>>> >     Hi guys,
>>> >     I'm wondering if there is any implementation
>>> >     for ParMETIS_V3_PartGeomKway()? All I can find is the
>>> >     implementation for ParMETIS_V3_PartKway and I'm wondering if
>>> >     including the vertex positions could help me get a better
>>> >     partitioning?
>>> > As far as communication goes, it will not help.
>>> >     Also I have a general question. Is minimizing number of edge cuts
>>> >     essentially the same as minimizing communication? I understand
>>> >     that they are related, but communication is proportional to the
>>> >     number of ghost points which is not exactly equal (its actually
>>> >     less than) to the number of edge cuts. So then is it possible that
>>> >     this could actually result in larger number of ghost points, at
>>> >     least for some of processors?
>>> > It of course depends on your problem and the graph you draw, but you
>>> > can always draw a graph
>>> > where the edge cut is exactly your communication.
>>> It might also be interesting to look at Zoltan's hypergraph partitioning
>>> which can better balance communications -
>>> http://www.cs.sandia.gov/zoltan/dev_html/dev_phg.html
>> I would caution you that one thing people are rarely careful about is
>> quantifying the effect of
>> latency vs communication volume. I would bet you $10 that the lion's
>> share of slow down is
>> due to load imbalance/latency rather than communication volume (since
>> comm links are so
>> big).
>> Just to add, edge cuts are a good proxy for communication volume on PDE
>> graphs, IMO, but they are not the same and I applaud Zoltan for optimizing
>> this directly.  Both edge cuts and #ghosts are decent metrics to indirectly
>> minimize number of partition neighbors (latency).   As Matt says this is
>> probably what you want to minimize, assuming good load balance.
>> Furthermore you don't really want to minimize any of these.  What you
>> want to minimize is the maximum cuts/neighbors/load of an any partition --
>> that is load balance (max/optimal).
>> Mark
>>    Matt
>>> Cheers
>>> Gerard
>> experiments lead.
>> -- Norbert Wiener
> <new_4_1.jpg><old_4_1.jpg><old_8_1.jpg><new_8_1.jpg>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120216/7df4751e/attachment-0001.htm>
