[petsc-users] PCGASMSetLocalSubdomains
Hui Zhang mike.hui.zhang at hotmail.com
Thu Feb 16 04:35:19 CST 2012
> On Feb 15, 2012, at 10:26 AM, Hui Zhang wrote:
>> On Feb 15, 2012, at 5:18 PM, Barry Smith wrote:
>>> try it
>> Yes, I'm trying.  Just one more question: why there is no *Get* LocalToGlobalMapping
>> so that when a Mat is with some LocalToGlobalMapping we can temporarily change with
>> another mapping and reset back to the original mapping.
>  There is.   Perhaps it is only in petsc-dev
>   Barry
I found it. Thank you very much! By GetLocalToGlobalMapping, I also find that the
submat's from PCGASM has not been SetLocalToGlobalMapping() yet when ModifySubMatrices
was called by PCGASM. Everything is ok and clear now. Thanks again!
>>> On Feb 15, 2012, at 10:07 AM, Hui Zhang wrote:
>>>> On Feb 15, 2012, at 11:19 AM, Hui Zhang wrote:
>>>>> Hi Dmitry,
>>>>> thanks a lot! Currently, I'm not using ISColoring. Just comes another question
>>>>> on PCGASMSetModifySubMatrices(). The user provided function has the prototype
>>>>>  func (PC pc,PetscInt nsub,IS *row,IS *col,Mat *submat,void *ctx);
>>>>> I think the coloumns from the parameter 'col' are always the same as the rows
>>>>> from the parameter 'row'. Because PCGASMSetLocalSubdomains() only accepts
>>>>> index sets but not rows and columns. Has I misunderstood something?
>>>> As I tested, the row and col are always the same.
>>>> I have a new question. Am I allowed to SetLocalToGlobalMapping() for the submat's
>>>> in the above func()?
>>>> thanks,
>>>> Hui
>>>>> thanks,
>>>>> Hui
>>>>> On Feb 11, 2012, at 3:36 PM, Dmitry Karpeev wrote:
>>>>>> Yes, that's right.
>>>>>> There is no good way to help the user assemble the subdomains at the moment beyond the 2D stuff.
>>>>>> It is expected that they are generated from mesh subdomains.
>>>>>> Each IS does carry the subdomains subcomm.
>>>>>> There is ISColoringToList() that is supposed to convert a "coloring" of indices to an array of ISs,
>>>>>> each having the indices with the same color and the subcomm that supports that color. It is
>>>>>> largely untested, though.  You could try using it and give us feedback on any problems you encounter.
>>>>>> Dmitry.
>>>>>> On Sat, Feb 11, 2012 at 6:06 AM, Hui Zhang <mike.hui.zhang at hotmail.com> wrote:
>>>>>> About PCGASMSetLocalSubdomains(), in the case of one subdomain supported by
>>>>>> multiple processors, shall I always create the arguments 'is[s]' and 'is_local[s]'
>>>>>> in a subcommunicator consisting of processors supporting the subdomain 's'?
>>>>>> The source code of PCGASMCreateSubdomains2D() seemingly does so.
>>>>>> Thanks,
>>>>>> Hui
