[petsc-users] Ghost point communication for Red-Black Gauss-Siedel
Sylvain Barbot sylbar.vainbot at gmail.com
Wed Feb 15 20:53:14 CST 2012
Hi Matt,
You're right, I'm not worried about the interior points, that why I'm
looking for updating the ghost points only - the interior points
unaffected by the process. Jed seems to indicate that it's not a
bottle neck.
Jed,
Would you recommend a particular step to improve cache performance?
Can you be a bit more specific?
Sylvain
2012/2/15 Matthew Knepley <knepley at gmail.com>:
> On Wed, Feb 15, 2012 at 5:25 PM, Sylvain Barbot <sylbar.vainbot at gmail.com>
> wrote:
>> Hi All,
>> I'm implementing an elasticity multi-grid solver with Petsc with
>> matrix shells. I am using the Red-Black Gauss-Siedel smoother. In the
>> middle of the Red-Black passes, I need to update the ghost points
>> between processors. To do that effectively, I'd like to update only
>> the ghost points between the different processors, instead of the
>> whole array. The goal is to do the most possible operations in place
> What does that mean? Updating ghost dofs means taking the value of that
> dof on the process that owns it, and copying it to all the processes which
> hold
> that as a ghost dof. This operation has no meaning for interior points.
>     Matt
>> in local array lx, and having to update global vector x only once. The
>> working matrix multiply smoothing operation is shown below. I'm using
>> Petsc 3.1. I read about
>> http://www.mcs.anl.gov/petsc/petsc-3.1/docs/manualpages/Vec/VecGhostUpdateBegin.html,
>> but I'm not entirely clear whether this does what I want or not.
>> SUBROUTINE matrixsmooth(A,b,omega,flag,shift,its,level,x,ierr)
>>    USE types
>>    USE heap
>>    USE petscsys
>>    USE petscda
>>    USE petscis
>>    USE petscvec
>>    USE petscmat
>>    USE petscpc
>>    USE petscksp
>>    IMPLICIT NONE
>>    Mat, INTENT(IN) :: A
>>    Vec, INTENT(IN) :: b
>>    Vec, INTENT(INOUT) :: x
>>    PetscReal, INTENT(IN) :: omega,shift
>>    MatSORType, INTENT(IN) :: flag
>>    PetscInt, INTENT(IN) :: its, level ! iterations, multi-grid level
>>    PetscErrorCode, INTENT(OUT) :: ierr
>>    Vec :: lx,lb
>>    PetscInt :: istart,iend
>>    PetscScalar, POINTER :: px(:) ! pointer to solution array
>>    PetscScalar, POINTER :: pb(:) ! pointer to body-force array
>>    INTEGER :: rank,isize,i,k
>>    INTEGER :: sw,off,p
>>    INTEGER :: i2,i3,i2i,i3i, &
>>               i000,i0p0,i00p, &
>>               i0m0,i00m
>>    TYPE(DALOCALINFOF90) :: info
>>    CALL MPI_COMM_RANK(PETSC_COMM_WORLD,rank,ierr)
>>    CALL MPI_COMM_SIZE(PETSC_COMM_WORLD,isize,ierr)
>>    CALL VecGetOwnershipRange(x,istart,iend,ierr)
>>    ! allocate memory for local vector with ghost points
>>    CALL DACreateLocalVector(c%daul(1+level),lx,ierr)
>>    CALL VecDuplicate(lx,lb,ierr)
>>    ! retrieve forcing term b with ghost points
>>    CALL DAGlobalToLocalBegin(c%daul(1+level),b,INSERT_VALUES,lb,ierr)
>>    CALL DAGlobalToLocalEnd(c%daul(1+level),b,INSERT_VALUES,lb,ierr)
>>    ! obtain a pointer to local data
>>    CALL VecGetArrayF90(lx,px,ierr);
>>    CALL VecGetArrayF90(lb,pb,ierr);
>>    ! geometry info about local vector and padding
>>    CALL DAGetLocalInfoF90(c%daul(1+level),info,ierr);
>>    ! retrieve stencil width (ghost-point padding)
>>    CALL DAGetInfo(c%daul(1+level),PETSC_NULL_INTEGER,PETSC_NULL_INTEGER, &
>> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
>>                   sw,PETSC_NULL_INTEGER, &
>>                   PETSC_NULL_INTEGER,ierr);
>>    ! offset due to node topology
>>    off=MOD(info%xm+info%ym,2)
>>    ! fast smoothing (relaxation) its=number of iteration
>>    DO k=1,its
>>       ! Red-Black Gauss-Siedel scheme
>>       DO p=0,1
>>          ! retrieve initial guess x with ghost points
>>          CALL
>> DAGlobalToLocalBegin(c%daul(1+level),x,INSERT_VALUES,lx,ierr)
>>          CALL DAGlobalToLocalEnd(c%daul(1+level),x,INSERT_VALUES,lx,ierr)
>>          ! smoothing (relaxation)
>>          DO i=istart+p+off,iend-1,info%dof*2
>>             i3=(i-istart)/(info%xm*info%dof)
>>             i2=(i-istart-i3*info%xm*info%dof)/info%dof
>>             i3=i3+i3i    ! i3 in ( 0 .. sx3-1 )
>>             i2=i2+i2i    ! i2 in ( 0 .. sx2-1 )
>>             i000=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
>>             i0p0=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i+1)*info%dof
>>             i00p=1+((sw+i3-i3i+1)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
>>             i0m0=1+((sw+i3-i3i+0)*(info%xm+2*sw)+sw+i2-i2i-1)*info%dof
>>             i00m=1+((sw+i3-i3i-1)*(info%xm+2*sw)+sw+i2-i2i+0)*info%dof
>>             px(i000+IU1)=px(i000+IU1)+ &
>>                     (pb(i000+IU1)-((+(px(i0p0+IU1)-px(i000+IU1)
>> )-(px(i000+IU1)-px(i0m0+IU1) )) &
>> +(+(px(i00p+IU1)-px(i000+IU1) )-(px(i000+IU1)-px(i00m+IU1) )))) /
>> (-4._8)
>>          END DO
>>          ! publish new values of x for its global vector
>>          CALL DALocalToGlobal(c%daul(1+level),lx,INSERT_VALUES,x,ierr)
>>       END DO
>>    END DO
>>    ! dispose of the local vectors
>>    CALL VecRestoreArrayF90(lx,px,ierr)
>>    CALL VecRestoreArrayF90(lb,pb,ierr)
>>    CALL DARestoreLocalVector(c%daul(1+level),lx,ierr)
>>    CALL DARestoreLocalVector(c%daul(1+level),lb,ierr)
>>  END SUBROUTINE matrixsmooth
>> Could this be changed to something like:
>>    ... INITIALIZE...
>>    CALL DAGlobalToLocalBegin(c%daul(1+c%level),x,INSERT_VALUES,lx,ierr)
>>    CALL DAGlobalToLocalEnd(c%daul(1+c%level),x,INSERT_VALUES,lx,ierr)
>>    DO k=1,its
>>       DO p=0,1
>>             ...STENCIL OPERATION...
>>          END DO
>>          ...UPDATE GHOST POINTS...
>>       END DO
>>    END DO
>>   ...CLEAN MEMORY...
>> Any recommendation?
>> Best wishes,
>> Sylvain Barbot
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
