[petsc-users] Null space of discrete Laplace with periodic boundary conditions
Tue Feb 14 09:25:58 CST 2012
On Tue, Feb 14, 2012 at 09:20, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> I discretize the Laplace operator (using finite element) on the unit
> square equipped with periodic boundary conditions on all four edges. Is it
> correct that the null space is still constant? I wounder, because when I
> run the same code on a sphere (so a 2D surface embedded in 3D), the
> resulting matrix is non-singular. I thought, that both cases should be
> somehow equal with respect to the null space?
The continuum operators for both cases have a constant null space, so if
either is nonsingular in your finite element code, it's a discretization
problem.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120214/a819d789/attachment.htm>
