[petsc-users] -mat_partitioning_view
Mon Feb 13 18:22:20 CST 2012
On Mon, Feb 13, 2012 at 18:17, Mohammad Mirzadeh <mirzadeh at gmail.com> wrote:
> When using -mat_partitioning_view flag, PETSc reports number of edge cuts.
> Is this the number of edge cuts in the graph for the new partitioning (i.e.
> using new global numbering)?
yes
> Also, does the partitioning favors minimizing the edge cuts over having
> equal number of points per processor? If so, how can this be altered?
Metis and ParMetis balance the partitions "equally" (within 1 vertex), then
tries to minimize the edge cut. Assuming that is the partitioner you are
using, that is what you will get.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120213/18b90c8d/attachment.htm>
