[petsc-users] MatSetValues() for MATMPICUSP
recrusader recrusader at gmail.com
Fri Feb 10 15:12:30 CST 2012
Dear Jed,
The first example works. However, the example uses MatSetValuesStencil()
not MatSetValues(). Are they same?
Thanks a lot,
Yujie
On Fri, Feb 10, 2012 at 2:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Feb 10, 2012 at 14:49, recrusader <recrusader at gmail.com> wrote:
>> Since MATMPIAIJ works (I didn't change anything. Just set the vec and mat
>> types to mpicusp and mpiaijcusp for GPU), I think the problem is likely
>> from MatSetValues_MPIAIJ().
>> Which PETSc examples can test this function?
> Try src/ksp/ksp/examples/tutorials/ex43.c and
> src/snes/examples/tutorials/ex48.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120210/00b99f2e/attachment.htm>
