[petsc-users] MatSetValues() for MATMPICUSP
recrusader recrusader at gmail.com
Fri Feb 10 14:49:14 CST 2012
Since MATMPIAIJ works (I didn't change anything. Just set the vec and mat
types to mpicusp and mpiaijcusp for GPU), I think the problem is likely
from MatSetValues_MPIAIJ().
Which PETSc examples can test this function? I can try to use it to test.
Thanks a lot, Jed.
Best,
Yujie
On Fri, Feb 10, 2012 at 2:44 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Feb 10, 2012 at 14:35, recrusader <recrusader at gmail.com> wrote:
>> MATMPIAIJ works ;(.
> Can you send a reproducible test case? (Instructions for how to run a
> Libmesh example that would cause this problem is okay, producing it with a
> PETSc example would be better.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120210/dfbc86e9/attachment.htm>
