[petsc-users] VecScatter Question
Mohammad Mirzadeh mirzadeh at gmail.com
Thu Feb 9 17:52:53 CST 2012
Thanks Satish. That all makes sense.
Truth is I am trying to move data from a parallel vector to a serial one on
rank 0. I make an index set, in parallel, with stride 1 and use it for both
source and destination and i believe that should do the job ... but it does
not. Somehow it seems that the values from other processors do not get
inserted in the serial vector on rank 0!
This seems it should be so simple and I'm not sure if there is a bug
somewhere in my code or I'm still confused about IS and VecScatter!
Mohammad
On Thu, Feb 9, 2012 at 3:42 PM, Satish Balay <balay at mcs.anl.gov> wrote
> On Thu, 9 Feb 2012, Mohammad Mirzadeh wrote:
> > So this actually means it somehow matches the local indices?
> Hm - no local indices here.
> > What i mean by that is,
> > y[ iy[i] ] = x[ ix[i] ].
> Sure - with global indices.
> > Is that why ix and iy should have the same size?
> When you specify data movement - you specify both source and
> destination for each element that is to be moved. If you are moving n
> elements - you have n sources, and n destination values - hence ix[n],
> iy[n]
> Satish
> > Mohammad
> > On Thu, Feb 9, 2012 at 3:17 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > Hi guys,
> > > > I'm just wondering if I understand how the VecScatter works.
> Considering
> > > > (petsc 3.2-p6 manual page 53):
> > > > VecScatterCreate(Vec x,IS ix,Vec y,IS iy,VecScatter *ctx);
> > > > VecScatterBegin(VecScatter ctx,Vec x,Vec y,INSERT VALUES,SCATTER
> > > FORWARD);
> > > > VecScatterEnd(VecScatter ctx,Vec x,Vec y,INSERT VALUES,SCATTER
> FORWARD);
> > > > VecScatterDestroy(VecScatter *ctx);
> > > > is the following statement correct?
> > > > VecScatter looks into "ix" and "iy" index sets and `matches' the
> global
> > > > indecies between the two to copy data from vector "x" to vector "y".
> For
> > > > example, if "ix" maps local index "1" to global index "10",
> VecScatter
> > > > looks inside "iy" to find a local index that is mapped to global
> index
> > > "10"
> > > > and sends the data accordingly to the correct processor.
> > > nope - it means - if you have x[10],y[10]:
> > > ix = {1,5,9}
> > > iy = {0,2,1}
> > > Then you get:
> > > y[0] = x[1]
> > > y[2] = x[5]
> > > y[1] = x[9]
> > > [all numbers above are global indices]
> > > Satish
> > > > Thanks,
> > > > Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120209/1c9aef3c/attachment.htm>
