[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Tue Feb 7 16:19:01 CST 2012
On Wed, Feb 8, 2012 at 01:12, Jack Poulson <jack.poulson at gmail.com> wrote:
> Yes, one could argue that PetscScalar can behave like a custom complex
> class, but with only a single instantiation choice through the preprocessor
> where each implementation was completely separate. If this type of logic
> was pulled into the language instead of lying at the preprocessor stage,
> then it would result in a custom complex class like I am arguing for.
> Either way std::complex is not being used for quads.
I think the typedefs are good enough for the 99%, but I was just teasing.
> Any way, it sounds like the current approach will work just fine for
> PETSc, so I will shut up. The only other argument would be if someone
> wanted to compute using some exotic datatype like the Gaussian integers,
> but that would require a subset of the functionality of standard complex
> class that only assumed a ring instead of a field.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120208/e9186715/attachment-0001.htm>
