[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Jack Poulson jack.poulson at gmail.com
Tue Feb 7 12:10:22 CST 2012
On Tue, Feb 7, 2012 at 11:29 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 7, 2012 at 11:20 AM, recrusader <recrusader at gmail.com> wrote:
>> Whether is it possible to find an efficient mechanism to do the
>> conversion between std::complex and cusp::complex when the conversion is
>> necessary.
> That does not matter. This is a compile error. We are not going to change
> this right now, and it seems like you are not going
> make the necessary changes, so I would say that complex numbers are not
> supported with our GPU code right now. The
> change would involve using cusp::complex for PetscScalar, and I am not
> sure how much work that would entail.
>    Matt
Matt,
You might be interested to hear that the C++03 standard states that "The
effect of instantiating the template complex for any type other than float,
double or long double is unspecified". Thus, complex quad precision with it
is probably a bad idea and, if I'm not mistaken, the standard does not
state that the class must store data in the form
double real, imag;
so this could potentially break interfaces (e.g., to BLAS or LAPACK). Maybe
it would be worthwhile to avoid usage of std::complex and simultaneously
fix the compatibility issue with cusp::complex. I recently ripped
std::complex out of Elemental for the above reasons.
Jack
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/62a35272/attachment.htm>
