[petsc-users] Hang at PetscLayoutSetUp()
Tue Feb 7 00:20:16 CST 2012
On Tue, Feb 7, 2012 at 08:34, Derek Gaston <friedmud at gmail.com> wrote:
> On Mon, Feb 6, 2012 at 10:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Are _all_ the processes making it here?
> Sigh.  I knew someone was going to ask that ;-)
> I'll have to write a short script to grab the stack trace from every one
> of the 10,000 processes to see where they are and try to find
> any anomalies.   Anyone have a script (or pieces of one) to do this that
> they wouldn't mind sharing?
> I did spot check quite a few and they were all in the same spot.
> Now here comes the weirdness: I left one of these processes attached in
> GDB for quite a while (10+ minutes) after the whole job had been hung for
> over an hour.  When I noticed that I had left it attached I detached GDB
> and.... the job started right up!  That is: it moved on past this problem!
>  How is that for some weirdness.  It might have just been coincidence... or
> maybe me stalling that process for a bit by attaching GDB nudged some
> communication in the right direction... I don't know.
Hmm, progress semantics of MPI should ensure completion. Stalling the
process with gdb should not change anything (assuming you weren't actually
making changes with gdb). Can you run with MPICH2?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120207/6535801d/attachment.htm>
