[petsc-users] access to matnest block (0,1) ?
Klaij, Christiaan C.Klaij at marin.nl
Wed Feb 1 01:42:38 CST 2012
>> Then what would be the best way to create the IS in this case?
>> Can it somehow be deduced from the separate blocks?
>The ISs define the row space of the blocks inside the global matrix.
Following ex28 I made two stride ISs to define the row space
but I'm still having trouble, this is for 2 procs:
  Matrix object:
    type=nest, rows=2, cols=2
    MatNest structure:
    (0,0) : prefix="a00_", type=mpiaij, rows=24, cols=24
    (0,1) : prefix="a01_", type=mpiaij, rows=24, cols=12
    (1,0) : prefix="a10_", type=mpiaij, rows=12, cols=24
    (1,1) : prefix="a11_", type=mpiaij, rows=12, cols=12
[0] Index set is permutation
[0] Number of indices in (stride) set 12
[0] 0 0
[0] 1 1
[0] 2 2
[0] 3 3
[0] 4 4
[0] 5 5
[0] 6 6
[0] 7 7
[0] 8 8
[0] 9 9
[0] 10 10
[0] 11 11
[1] Number of indices in (stride) set 12
[1] 0 12
[1] 1 13
[1] 2 14
[1] 3 15
[1] 4 16
[1] 5 17
[1] 6 18
[1] 7 19
[1] 8 20
[1] 9 21
[1] 10 22
[1] 11 23
[0] Number of indices in (stride) set 6
[0] 0 24
[0] 1 25
[0] 2 26
[0] 3 27
[0] 4 28
[0] 5 29
[1] Number of indices in (stride) set 6
[1] 0 30
[1] 1 31
[1] 2 32
[1] 3 33
[1] 4 34
[1] 5 35
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Arguments are incompatible!
[0]PETSC ERROR: Could not find index set!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./matnest-trycpp on a linux_64b named lin0133 by cklaij Wed Feb  1 08:33:40 2012
[0]PETSC ERROR: Libraries linked from /opt/refresco/64bit_intelv11.1_openmpi/petsc-3.2-p5/lib
[0]PETSC ERROR: Configure run at Thu Jan 26 13:44:12 2012
[0]PETSC ERROR: Configure options --prefix=/opt/refresco/64bit_intelv11.1_openmpi/petsc-3.2-p5 --with-mpi-dir=/opt/refresco/64bit_intelv11.1_openmpi/openmpi-1.4.4 --with-x=1 --with-mpe=0 --with-debugging=1 --with-clanguage=c++ --with-hypre-include=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/include --with-hypre-lib=/opt/refresco/64bit_intelv11.1_openmpi/hypre-2.7.0b/lib/libHYPRE.a --with-ml-include=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/include --with-ml-lib=/opt/refresco/64bit_intelv11.1_openmpi/ml-6.2/lib/libml.a --with-blas-lapack-dir=/opt/intel/mkl
[0]PETSC ERROR: MatNestFindIS() line 292 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: MatNestFindSubMat() line 350 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: MatGetSubMatrix_Nest() line 366 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: MatGetSubMatrix() line 7135 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/mat/interface/matrix.c
[0]PETSC ERROR: PCSetUp_FieldSplit() line 377 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: PCSetUp() line 819 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSetUp() line 260 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: KSPSolve() line 379 in /home/CKlaij/ReFRESCO/Libraries/build/petsc-3.2-p5/src/ksp/ksp/interface/itfunc.c
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
