[petsc-users] Direct Schur complement domain decomposition
Sat Dec 29 12:59:54 CST 2012
Sorry for the slow reply. What you are describing _is_ multifrontal
factorization, or alternatively, (non-iterative) substructuring. It is a
direct solve and boils down to a few large dense direct solves. Incomplete
factorization is one way of preventing the Schur complements from getting
too dense, but it's not very reliable.
There are many other ways of retaining structure in the supernodes (i.e.,
avoid unstructured dense matrices), at the expense of some error. These
methods "compress" the Schur complement using low-rank representations for
long-range interaction. These are typically combined with an iterative
method.
Multigrid and multilevel DD methods can be thought of as an alternate way
to compress (approximately) the long-range interaction coming from inexact
elimination (dimensional reduction of interfaces).
On Wed, Dec 19, 2012 at 10:25 AM, Stefan Kurzbach
<stefan.kurzbach at tuhh.de>wrote:
> Hello everybody,****
> in my recent research on parallelization of a 2D unstructured flow model
> code I came upon a question on domain decomposition techniques in “grids”.
> Maybe someone knows of any previous results on this?****
> Typically, when doing large simulations with many unknowns, the problem is
> distributed to many computer nodes and solved in parallel by some iterative
> method. Many of these iterative methods boil down to a large number of
> distributed matrix-vector multiplications (in the order of the number of
> iterations). This means there are many synchronization points in the
> algorithms, which makes them tightly coupled. This has been found to work
> well on clusters with fast networks.****
> Now my question:****
> What if there is a small number of very powerful nodes (say less than 10),
> which are connected by a slow network, e.g. several computer clusters
> connected over the internet (some people call this “grid computing”). I
> expect that the traditional iterative methods will not be as efficient here
> (any references?).****
> My guess is that a solution method with fewer synchronization points will
> work better, even though that method may be computationally more expensive
> than traditional methods. An example would be a domain composition approach
> with direct solution of the Schur complement on the interface. This
> requires that the interface size has to be small compared to the subdomain
> size. As this algorithm basically works in three decoupled phases (solve
> the subdomains for several right hand sides, assemble and solve the Schur
> complement system, correct the subdomain results) it should be suited well,
> but I have no idea how to test or otherwise prove it. Has anybody made any
> thoughts on this before, possibly dating back to the 80ies and 90ies, where
> slow networks were more common?****
> Best regards****
> Stefan****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121229/8f88887b/attachment.html>
