[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Wed Dec 26 22:52:41 CST 2012
-g is definitely on.  I'll send the configure.log file to the PETSc
maintenance e-mail, petsc-maint at mcs.anl.gov
<mailto:petsc-maint at mcs.anl.gov> .  -sanjay
On 12/26/12 6:46 PM, Matthew Knepley wrote:
> On Wed, Dec 26, 2012 at 8:34 PM, Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
>     For what it is worth.  I ran the problems with valgrind (before I
>     built the --with-shared-libraries version).
>     With spooles the run is essentially clean.  With superlu I see
>     lots of errors of the type:
> This looks like a well-known MPICH problem with valgrind reporting.
> However, these
> stacks look strange. You should have source line numbers if this is
> compiled with debugging
> and you should have the whole stack for MPICH.
> Also, why is libquadmath being linked?
>    Matt
>     ==91099== Syscall param writev(vector[...]) points to
>     uninitialised byte(s)
>     ==91099==    at 0x1245FF2: writev (in
>     /usr/lib/system/libsystem_kernel.dylib)
>     ==91099==    by 0x101209846: MPIDU_Sock_writev (in ./ex2)
>     ==91099==    by 0x101A2BA23: ???
>     ==91099==    by 0x1FFFFFFFB: ???
>     ==91099==    by 0x101A2BA0F: ???
>     ==91099==    by 0x10852053F: ???
>     ==91099==    by 0x101A24907: ???
>     ==91099==    by 0x7FFF5FBFE2DF: ???
>     ==91099==    by 0x1: ???
>     ==91099==    by 0x10120AF13: MPIDI_CH3_iSendv (in ./ex2)
>     ==91099==  Address 0x10712d0c8 is 136 bytes inside a block of size
>     1,661,792 alloc'd
>     ==91099==    at 0xC713: malloc (vg_replace_malloc.c:271)
>     ==91099==    by 0x100D5C6DF: superlu_malloc_dist (in ./ex2)
>     ==91099==    by 0x100D23375: doubleMalloc_dist (in ./ex2)
>     ==91099==    by 0x100D415C1: pdgstrs (in ./ex2)
>     ==91099==    by 0x100D3F852: pdgssvx (in ./ex2)
>     ==91099==    by 0x1007E5D38: MatSolve_SuperLU_DIST (in ./ex2)
>     ==91099==    by 0x1002BDA1E: MatSolve (in ./ex2)
>     ==91099==    by 0x1009EAF55: PCApply_LU (in ./ex2)
>     ==91099==    by 0x100AAE053: PCApply (in ./ex2)
>     ==91099==    by 0x100B1BCEE: KSPSolve_PREONLY (in ./ex2)
>     ==91099==    by 0x100B54F55: KSPSolve (in ./ex2)
>     ==91099==    by 0x1000022FC: main (in ./ex2)
>     On 12/26/12 5:24 PM, Sanjay Govindjee wrote:
>>     I have re-configured/built using:
>>     ./configure PETSC_ARCH=gnu_shared
>>     -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
>>     make  PETSC_ARCH=gnu_shared all
>>     make  PETSC_ARCH=gnu_shared test
>>     Using the same test problem
>>     (src/ksp/ksp/examples/tutorials/ex2.c), on the 100x100 case I get:
>>     sg-macbook-prolocal:tutorials sg$ make PETSC_ARCH=gnu_shared
>>     runex2spooles
>>     Norm of error 2.21422e-12 iterations 1
>>     runex2superlu
>>     Norm of error 7.66145e-13 iterations 1
>>     One the 500x500 case I get:
>>     runex2spooles
>>     Norm of error 2.69468e-10 iterations 1
>>     runex2superlu
>>     Norm of error 419.953 iterations 1
>>     otool shows:
>>     sg-macbook-prolocal:tutorials sg$ otool -L ex2
>>     ex2:
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpetsc.dylib
>>     (compatibility version 0.0.0, current version 0.0.0)
>>         /usr/X11/lib/libX11.6.dylib (compatibility version 10.0.0,
>>     current version 10.0.0)
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichcxx.dylib
>>     (compatibility version 0.0.0, current version 3.0.0)
>>         /usr/local/lib/libstdc++.6.dylib (compatibility version
>>     7.0.0, current version 7.17.0)
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libparmetis.dylib
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmetis.dylib
>>     /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
>>     (compatibility version 1.0.0, current version 1.0.0)
>>     /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichf90.dylib
>>         /usr/local/lib/libgfortran.3.dylib (compatibility version
>>     4.0.0, current version 4.0.0)
>>         /usr/local/lib/libquadmath.0.dylib (compatibility version
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpmpich.dylib
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpich.dylib
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libopa.1.dylib
>>     (compatibility version 2.0.0, current version 2.0.0)
>>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpl.1.dylib
>>     (compatibility version 3.0.0, current version 3.0.0)
>>         /usr/lib/libSystem.B.dylib (compatibility version 1.0.0,
>>     current version 159.1.0)
>>         /usr/local/lib/libgcc_s.1.dylib (compatibility version 1.0.0,
>>     On 12/26/12 3:08 PM, Matthew Knepley wrote:
>>>     On Wed, Dec 26, 2012 at 4:38 PM, Sanjay Govindjee
>>>     <s_g at berkeley.edu <mailto:s_g at berkeley.edu>> wrote:
>>>         I have a macbook pro (Mac OS X 10.7.5)
>>>         % uname -a
>>>         Darwin sg-macbook-prolocal.local 11.4.2 Darwin Kernel
>>>         Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012;
>>>         root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
>>>         I configured using:
>>>         ./configure --with-cc=icc --with-fc=ifort
>>>         so everything was built together.
>>>     Since
>>>       a) you have tried other compilers
>>>       b) we cannot reproduce it
>>>       c) we are building the library during configure
>>>     I would guess that some outside library, in your default link
>>>     path, is contaminating
>>>     the executable with symbols which override some of those in
>>>     SuperLU. The SuperLU
>>>     people are not super careful about naming. Could you
>>>       1) Try this same exercise using --with-shared-libraries
>>>       2) Once you do that, use otool -L on the executable so we can
>>>     see where everything comes from
>>>       Thanks,
>>>           Matt
>>>         On 12/26/12 1:34 PM, Hong Zhang wrote:
>>>             Sanjay:
>>>                 hmmm....I guess that is good news -- in that superlu
>>>                 is not broken. However,
>>>                 for me
>>>                 not so good news since I seems that there is nasty
>>>                 bug lurking on my
>>>                 machine.
>>>                 Any suggestions on chasing down the error?
>>>             How did you install your supelu_dist with petsc-3.3?
>>>             What machine do you use?
>>>             Hong
>>>                 On 12/26/12 1:23 PM, Hong Zhang wrote:
>>>                     Sanjay:
>>>                     I get
>>>                     petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec
>>>                     -n 2 ./ex2
>>>                     -ksp_monitor_short  -ksp_type preonly -pc_type lu
>>>                     -pc_factor_mat_solver_package superlu_dist -m
>>>                     500 -n 500
>>>                     Norm of error 1.92279e-11 iterations 1
>>>                     Hong
>>>                         I have done some more testing of the
>>>                         problem, continuing with
>>>                         src/ksp/ksp/examples/tutorials/ex2.c.
>>>                         The behavior I am seeing is that with
>>>                         smaller problems sizes superlu_dist
>>>                         is
>>>                         behaving properly
>>>                         but with larger problem sizes things seem to
>>>                         go wrong and what goes wrong
>>>                         is
>>>                         apparently consistent; the error appears
>>>                         both with my intel build as well
>>>                         as
>>>                         with my gcc build.
>>>                         I have two run lines:
>>>                         runex2superlu:
>>>                                   -@${MPIEXEC} -n 2 ./ex2
>>>                         -ksp_monitor_short -m 100 -n 100
>>>                         -ksp_type
>>>                         preonly -pc_type lu
>>>                         runex2spooles:
>>>                         -ksp_type
>>>                         preonly -pc_type lu
>>>                         -pc_factor_mat_solver_package spooles
>>>                           From my intel build, I get
>>>                         runex2superlu
>>>                         runex2spooles
>>>                           From my GCC build, I get
>>>                         runex2superlu
>>>                         runex2spooles
>>>                         If I change the -m 100 -n 100 to -m 500 -n
>>>                         500, I get for my intel build
>>>                         runex2superlu
>>>                         runex2spooles
>>>                           From my GCC build with -m 500 -n 500, I get
>>>                         runex2superlu
>>>                         runex2spooles
>>>                         Any suggestions will be greatly appreciated.
>>>                         -sanjay
>>>                         On 12/23/12 6:42 PM, Matthew Knepley wrote:
>>>                         On Sun, Dec 23, 2012 at 9:37 PM, Sanjay
>>>                         wrote:
>>>                             I decided to go with
>>>                             ksp/ksp/exampeles/tutorials/ex2.c; I was
>>>                             unsure how
>>>                             to convert the run lines for
>>>                             snes/examples/ex5.c to work with a direct
>>>                             solver as I am not versed in SNES options.
>>>                             Notwithstanding something strange is
>>>                             happening only on select examples.
>>>                             With ksp/ksp/exampeles/tutorials/ex2.c
>>>                             and the run line:
>>>                             -ksp_monitor_short -m 20 -n 20 -ksp_type
>>>                             preonly
>>>                             -pc_type lu
>>>                             I get good results (of the order):
>>>                             Norm of error 1.85464e-14 iterations 1
>>>                             using both superlu_dist and spooles.
>>>                             My BLAS/LAPACK: -llapack -lblas (so
>>>                             native to my machine).
>>>                             If you can guide me on a run line for
>>>                             the snes ex5.c I can try that too.
>>>                             I'll also try to construct a GCC build
>>>                             later to see if that is an issue.
>>>                         Same line on ex5, but ex2 is good enough.
>>>                         However, it will not tell us
>>>                         anything new. Try another build.
>>>                              Matt
>>>                             -sanjay
>>>                             On 12/23/12 5:58 PM, Matthew Knepley wrote:
>>>                             On Sun, Dec 23, 2012 at 8:08 PM, Sanjay
>>>                             wrote:
>>>                                 Not sure what you mean by where is
>>>                                 your matrix?  I am simply running
>>>                                 ex6
>>>                                 in the ksp/examples/tests directory.
>>>                                 The reason I ran this test is
>>>                                 because I was seeing the same behavior
>>>                                 with
>>>                                 my finite element code (on perfectly
>>>                                 benign problems).
>>>                                 Is there a built-in test that you
>>>                                 use to check that superlu_dist is
>>>                                 working properly with petsc?
>>>                                 i.e. something you know that works
>>>                                 with with petsc 3.3-p5?
>>>                             1) Run it on a SNES ex5 (or KSP ex2),
>>>                             which is a nice Laplacian
>>>                             2) Compare with MUMPS
>>>                                  Matt
>>>                                 -sanjay
>>>                                 On 12/23/12 4:56 PM, Jed Brown wrote:
>>>                                 Where is your matrix? It might be
>>>                                 ending up with a very bad pivot. If
>>>                                 the
>>>                                 problem can be reproduced, it should
>>>                                 be reported to the SuperLU_DIST
>>>                                 developers to fix. (Note that we do
>>>                                 not see this with other matrices.)
>>>                                 You
>>>                                 can also try MUMPS.
>>>                                 On Sun, Dec 23, 2012 at 6:48 PM,
>>>                                 wrote:
>>>                                     I wanted to use SuperLU Dist to
>>>                                     perform a direct solve but seem
>>>                                     to be
>>>                                     encountering
>>>                                     a problem.  I was wonder if this
>>>                                     is a know issue and if there is a
>>>                                     solution for it.
>>>                                     The problem is easily observed
>>>                                     using ex6.c in
>>>                                     src/ksp/ksp/examples/tests.
>>>                                     Out of the box: make runex6
>>>                                     produces a residual error of
>>>                                     O(1e-11), all
>>>                                     is well.
>>>                                     I then changed the run to run on
>>>                                     two processors and add the flag
>>>                                     spooles  this produces a
>>>                                     residual error
>>>                                     of
>>>                                     O(1e-11), all is still well.
>>>                                     I then switch over to
>>>                                     superlu_dist and
>>>                                     the
>>>                                     residual error comes back as
>>>                                     22.6637!  Something seems very
>>>                                     wrong.
>>>                                     My build is perfectly vanilla:
>>>                                     export
>>>                                     PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>>                                     export PETSC_ARCH=intel
>>>                                     --with-fc=ifort  \
>>>                                     make
>>>                                     PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel
>>>                                     all
>>>                                     make
>>>                                     test
>>>                                     -sanjay
>>>                                 Sanjay Govindjee, PhD, PE
>>>                                 Professor of Civil Engineering
>>>                                 Vice Chair for Academic Affairs
>>>                                 779 Davis Hall
>>>                                 Structural Engineering, Mechanics
>>>                                 and Materials
>>>                                 Department of Civil Engineering
>>>                                 University of California
>>>                                 Berkeley, CA 94720-1710
>>>                                 Voice: +1 510 642 6060
>>>                                 <tel:%2B1%20510%20642%206060>
>>>                                 FAX: +1 510 643 5264
>>>                                 <tel:%2B1%20510%20643%205264>
>>>                                 s_g at berkeley.edu
>>>                                 http://www.ce.berkeley.edu/~sanjay
>>>                                 <http://www.ce.berkeley.edu/%7Esanjay>
>>>                                 New Books:
>>>                                 Engineering Mechanics of Deformable
>>>                                 Solids: A Presentation with Exercises
>>>                                 http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>>                                 http://ukcatalogue.oup.com/product/9780199651641.do
>>>                                 http://amzn.com/0199651647
>>>                                 Engineering Mechanics 3 (Dynamics)
>>>                                 http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>>>                                 http://amzn.com/3642140181
>>>                             What most experimenters take for granted
>>>                             before they begin their
>>>                             experiments is infinitely more
>>>                             interesting than any results to which
>>>                             their
>>>                             experiments lead.
>>>                             -- Norbert Wiener
>>>                         experiments
>>>                         is infinitely more interesting than any
>>>                         results to which their
>>>                         experiments
>>>                         lead.
>>>                         -- Norbert Wiener
>>>                 779 Davis Hall
>>>                 Structural Engineering, Mechanics and Materials
>>>                 Voice: +1 510 642 6060 <tel:%2B1%20510%20642%206060>
>>>                 FAX: +1 510 643 5264 <tel:%2B1%20510%20643%205264>
>>>                 New Books:
>>>         779 Davis Hall
>>>         New Books:
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     which their experiments lead.
>>>     -- Norbert Wiener
>>     779 Davis Hall
>>     Voice:+1 510 642 6060  <tel:%2B1%20510%20642%206060>
>>     FAX:+1 510 643 5264  <tel:%2B1%20510%20643%205264>
>>     http://www.ce.berkeley.edu/~sanjay  <http://www.ce.berkeley.edu/%7Esanjay>
>>     New Books:
>     779 Davis Hall
>     New Books:
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
779 Davis Hall
s_g at berkeley.edu
New Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121226/5bd6bb78/attachment-0001.html>
