[petsc-users] Using superlu_dist in a direct solve
Sun Dec 23 20:42:56 CST 2012
On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>  I decided to go with ksp/ksp/exampeles/tutorials/ex2.c; I was unsure how
> to convert the run lines for snes/examples/ex5.c to work with a direct
> solver as I am not versed in SNES options.
> Notwithstanding something strange is happening only on select examples.
> With ksp/ksp/exampeles/tutorials/ex2.c and the run line:
> -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m 20 -n 20 -ksp_type preonly
> -pc_type lu -pc_factor_mat_solver_package superlu_dist
> I get good results (of the order):
> Norm of error 1.85464e-14 iterations 1
> using both superlu_dist and spooles.
> My BLAS/LAPACK: -llapack -lblas (so native to my machine).
> If you can guide me on a run line for the snes ex5.c I can try that too.
> I'll also try to construct a GCC build later to see if that is an issue.
Same line on ex5, but ex2 is good enough. However, it will not tell us
anything new. Try another build.
   Matt
> -sanjay
> On 12/23/12 5:58 PM, Matthew Knepley wrote:
> On Sun, Dec 23, 2012 at 8:08 PM, Sanjay Govindjee <s_g at berkeley.edu>wrote:
>>  Not sure what you mean by where is your matrix?  I am simply running ex6
>> in the ksp/examples/tests directory.
>> The reason I ran this test is because I was seeing the same behavior with
>> my finite element code (on perfectly benign problems).
>> Is there a built-in test that you use to check that superlu_dist is
>> working properly with petsc?
>> i.e. something you know that works with with petsc 3.3-p5?
>  1) Run it on a SNES ex5 (or KSP ex2), which is a nice Laplacian
>  2) Compare with MUMPS
>     Matt
>>  -sanjay
>> On 12/23/12 4:56 PM, Jed Brown wrote:
>> Where is your matrix? It might be ending up with a very bad pivot. If the
>> problem can be reproduced, it should be reported to the SuperLU_DIST
>> developers to fix. (Note that we do not see this with other matrices.) You
>> can also try MUMPS.
>> On Sun, Dec 23, 2012 at 6:48 PM, Sanjay Govindjee <s_g at berkeley.edu>wrote:
>>>  I wanted to use SuperLU Dist to perform a direct solve but seem to be
>>> encountering
>>> a problem.  I was wonder if this is a know issue and if there is a
>>> solution for it.
>>> The problem is easily observed using ex6.c in src/ksp/ksp/examples/tests.
>>> Out of the box: make runex6 produces a residual error of O(1e-11), all
>>> is well.
>>> I then changed the run to run on two processors and add the flag
>>> -pc_factor_mat_solver_package spooles  this produces a residual error of
>>> O(1e-11), all is still well.
>>> I then switch over to -pc_factor_mat_solver_package superlu_dist and the
>>> residual error comes back as 22.6637!  Something seems very wrong.
>>> My build is perfectly vanilla:
>>> export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>> export PETSC_ARCH=intel
>>> ./configure --with-cc=icc --with-fc=ifort  \
>>> -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel all
>>> make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel test
>>> -sanjay
>> Sanjay Govindjee, PhD, PE
>> Professor of Civil Engineering
>> Vice Chair for Academic Affairs
>> 779 Davis Hall
>> Structural Engineering, Mechanics and Materials
>> Department of Civil Engineering
>> University of California
>> Berkeley, CA 94720-1710
>> Voice:  +1 510 642 6060
>> FAX:    +1 510 643 5264s_g at berkeley.eduhttp://www.ce.berkeley.edu/~sanjay
>> New Books:
>> Engineering Mechanics of Deformable
>> Solids: A Presentation with Exerciseshttp://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641http://ukcatalogue.oup.com/product/9780199651641.dohttp://amzn.com/0199651647
>> Engineering Mechanics 3 (Dynamics)http://www.springer.com/materials/mechanics/book/978-3-642-14018-1http://amzn.com/3642140181
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121223/3cfc8024/attachment.html>
