[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Sun Dec 23 20:01:35 CST 2012
Would it be acceptable to use SPOOLES for the comparison?  or is MUMPS
needed (I would like to avoid re-doing my installation).
On 12/23/12 5:58 PM, Matthew Knepley wrote:
> On Sun, Dec 23, 2012 at 8:08 PM, Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
>     Not sure what you mean by where is your matrix?  I am simply
>     running ex6 in the ksp/examples/tests directory.
>     The reason I ran this test is because I was seeing the same
>     behavior with my finite element code (on perfectly benign problems).
>     Is there a built-in test that you use to check that superlu_dist
>     is working properly with petsc?
>     i.e. something you know that works with with petsc 3.3-p5?
> 1) Run it on a SNES ex5 (or KSP ex2), which is a nice Laplacian
> 2) Compare with MUMPS
>    Matt
>     -sanjay
>     On 12/23/12 4:56 PM, Jed Brown wrote:
>>     Where is your matrix? It might be ending up with a very bad
>>     pivot. If the problem can be reproduced, it should be reported to
>>     the SuperLU_DIST developers to fix. (Note that we do not see this
>>     with other matrices.) You can also try MUMPS.
>>     On Sun, Dec 23, 2012 at 6:48 PM, Sanjay Govindjee
>>     <s_g at berkeley.edu <mailto:s_g at berkeley.edu>> wrote:
>>         I wanted to use SuperLU Dist to perform a direct solve but
>>         seem to be encountering
>>         a problem.  I was wonder if this is a know issue and if there
>>         is a solution for it.
>>         The problem is easily observed using ex6.c in
>>         src/ksp/ksp/examples/tests.
>>         Out of the box: make runex6 produces a residual error of
>>         O(1e-11), all is well.
>>         I then changed the run to run on two processors and add the flag
>>         -pc_factor_mat_solver_package spooles this produces a
>>         residual error of O(1e-11), all is still well.
>>         I then switch over to -pc_factor_mat_solver_package
>>         superlu_dist and the
>>         residual error comes back as 22.6637! Something seems very wrong.
>>         My build is perfectly vanilla:
>>         export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>         export PETSC_ARCH=intel
>>         ./configure --with-cc=icc --with-fc=ifort \
>>         -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
>>         make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel all
>>         make PETSC_DIR=/Users/sg/petsc-3.3-p5/ PETSC_ARCH=intel test
>>         -sanjay
>     Sanjay Govindjee, PhD, PE
>     Professor of Civil Engineering
>     Vice Chair for Academic Affairs
>     779 Davis Hall
>     Structural Engineering, Mechanics and Materials
>     Department of Civil Engineering
>     University of California
>     Berkeley, CA 94720-1710
>     Voice:+1 510 642 6060  <tel:%2B1%20510%20642%206060>
>     FAX:+1 510 643 5264  <tel:%2B1%20510%20643%205264>
>     http://www.ce.berkeley.edu/~sanjay  <http://www.ce.berkeley.edu/%7Esanjay>
>     New Books:
>     Engineering Mechanics of Deformable
>     Solids: A Presentation with Exercises
>     http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>     http://ukcatalogue.oup.com/product/9780199651641.do
>     http://amzn.com/0199651647
>     Engineering Mechanics 3 (Dynamics)
>     http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>     http://amzn.com/3642140181
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
779 Davis Hall
Voice:  +1 510 642 6060
FAX:    +1 510 643 5264
s_g at berkeley.edu
New Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121223/811e7977/attachment-0001.html>
