[petsc-users] LU factorization and solution of independent matrices does not scale, why?
Fri Dec 21 10:01:27 CST 2012
Can you reproduce this in a simpler environment so that we can report it?
As I understand your statement, it sounds like you could reproduce by
changing src/ksp/ksp/examples/tutorials/ex10.c to create a subcomm of size
4 and the using that everywhere, then compare log_summary running on 4
cores to running on more (despite everything really being independent)
It would also be worth using an MPI profiler to see if it's really spending
a lot of time in MPI_Iprobe. Since SuperLU_DIST does not use MPI_Iprobe, it
may be something else.
On Fri, Dec 21, 2012 at 8:51 AM, Thomas Witkowski <
Thomas.Witkowski at tu-dresden.de> wrote:
> I use a modified MPICH version. On the system I use for these benchmarks I
> cannot use another MPI library.
> I'm not fixed to MUMPS. Superlu_dist, for example, works also perfectly
> for this. But there is still the following problem I cannot solve: When I
> increase the number of coarse space matrices, there seems to be no scaling
> direct solver for this. Just to summaries:
> - one coarse space matrix is created always by one "cluster" consisting of
> four subdomanins/MPI tasks
> - the four tasks are always local to one node, thus inter-node network
> communication is not required for computing factorization and solve
> - independent of the number of cluster, the coarse space matrices are the
> same, have the same number of rows, nnz structure but possibly different
> values
> - there is NO load unbalancing
> - the matrices must be factorized and there are a lot of solves (> 100)
> with them
> It should be pretty clear, that computing LU factorization and solving
> with it should scale perfectly. But at the moment, all direct solver I
> tried (mumps, superlu_dist, pastix) are not able to scale. The loos of
> scale is really worse, as you can see from the numbers I send before.
> Any ideas? Suggestions? Without a scaling solver method for these kind of
> systems, my multilevel FETI-DP code is just more or less a joke, only some
> orders of magnitude slower than standard FETI-DP method :)
> Thomas
> Zitat von Jed Brown <jedbrown at mcs.anl.gov>:
>  MUMPS uses MPI_Iprobe on MPI_COMM_WORLD (hard-coded). What MPI
>> implementation have you been using? Is the behavior different with a
>> different implementation?
>> On Fri, Dec 21, 2012 at 2:36 AM, Thomas Witkowski <
>> thomas.witkowski at tu-dresden.de**> wrote:
>>  Okay, I did a similar benchmark now with PETSc's event logging:
>>> UMFPACK
>>>  16p: Local solve          350 1.0 2.3025e+01 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 63  0  0  0 52  63  0  0  0 51     0
>>>  64p: Local solve          350 1.0 2.3208e+01 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 60  0  0  0 52  60  0  0  0 51     0
>>> 256p: Local solve          350 1.0 2.3373e+01 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 49  0  0  0 52  49  0  0  0 51     1
>>> MUMPS
>>>  16p: Local solve          350 1.0 4.7183e+01 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 75  0  0  0 52  75  0  0  0 51     0
>>>  64p: Local solve          350 1.0 7.1409e+01 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 78  0  0  0 52  78  0  0  0 51     0
>>> 256p: Local solve          350 1.0 2.6079e+02 1.1 5.00e+04 1.0 0.0e+00
>>> 0.0e+00 7.0e+02 82  0  0  0 52  82  0  0  0 51     0
>>> As you see, the local solves with UMFPACK have nearly constant time with
>>> increasing number of subdomains. This is what I expect. The I replace
>>> UMFPACK by MUMPS and I see increasing time for local solves. In the last
>>> columns, UMFPACK has a decreasing value from 63 to 49, while MUMPS's
>>> column
>>> increases here from 75 to 82. What does this mean?
>>> Thomas
>>> Am 21.12.2012 02:19, schrieb Matthew Knepley:
>>>  On Thu, Dec 20, 2012 at 3:39 PM, Thomas Witkowski
>>>> <Thomas.Witkowski at tu-dresden.****de <Thomas.Witkowski at tu-dresden.**de<Thomas.Witkowski at tu-dresden.de>
>>>> wrote:
>>>>  I cannot use the information from log_summary, as I have three
>>>>> different
>>>>> LU
>>>>> factorizations and solve (local matrices and two hierarchies of coarse
>>>>> grids). Therefore, I use the following work around to get the timing of
>>>>> the
>>>>> solve I'm intrested in:
>>>>>  You misunderstand how to use logging. You just put these thing in
>>>> separate stages. Stages represent
>>>> parts of the code over which events are aggregated.
>>>>     Matt
>>>>       MPI::COMM_WORLD.Barrier();
>>>>>      wtime = MPI::Wtime();
>>>>>      KSPSolve(*(data->ksp_schur_****primal_local), tmp_primal,
>>>>> tmp_primal);
>>>>>      FetiTimings::fetiSolve03 += (MPI::Wtime() - wtime);
>>>>> The factorization is done explicitly before with "KSPSetUp", so I can
>>>>> measure the time for LU factorization. It also does not scale! For 64
>>>>> cores,
>>>>> I takes 0.05 seconds, for 1024 cores 1.2 seconds. In all calculations,
>>>>> the
>>>>> local coarse space matrices defined on four cores have exactly the same
>>>>> number of rows and exactly the same number of non zero entries. So,
>>>>> from
>>>>> my
>>>>> point of view, the time should be absolutely constant.
>>>>> Thomas
>>>>> Zitat von Barry Smith <bsmith at mcs.anl.gov>:
>>>>>     Are you timing ONLY the time to factor and solve the subproblems?
>>>>>  Or
>>>>>> also the time to get the data to the collection of 4 cores at a  time?
>>>>>>     If you are only using LU for these problems and not elsewhere in
>>>>>>  the
>>>>>> code you can get the factorization and time from MatLUFactor()  and
>>>>>> MatSolve() or you can use stages to put this calculation in its  own
>>>>>> stage
>>>>>> and use the MatLUFactor() and MatSolve() time from that  stage.
>>>>>> Also look at the load balancing column for the factorization and
>>>>>>  solve
>>>>>> stage, it is well balanced?
>>>>>>     Barry
>>>>>> On Dec 20, 2012, at 2:16 PM, Thomas Witkowski
>>>>>> <thomas.witkowski at tu-dresden.****de <thomas.witkowski at tu-dresden.**de<thomas.witkowski at tu-dresden.de>
>>>>>> wrote:
>>>>>>  In my multilevel FETI-DP code, I have localized course matrices,
>>>>>>  which
>>>>>>> are defined on only a subset of all MPI tasks, typically  between 4
>>>>>>> and 64
>>>>>>> tasks. The MatAIJ and the KSP objects are both  defined on a MPI
>>>>>>> communicator, which is a subset of  MPI::COMM_WORLD. The LU
>>>>>>> factorization of
>>>>>>> the matrices is computed  with either MUMPS or superlu_dist, but both
>>>>>>> show
>>>>>>> some scaling  property I really wonder of: When the overall problem
>>>>>>> size is
>>>>>>> increased, the solve with the LU factorization of the local  matrices
>>>>>>> does
>>>>>>> not scale! But why not? I just increase the number of  local
>>>>>>> matrices,
>>>>>>> but
>>>>>>> all of them are independent of each other. Some  example: I use 64
>>>>>>> cores,
>>>>>>> each coarse matrix is spanned by 4 cores  so there are 16 MPI
>>>>>>> communicators
>>>>>>> with 16 coarse space matrices.  The problem need to solve 192 times
>>>>>>> with the
>>>>>>> coarse space systems,  and this takes together 0.09 seconds. Now I
>>>>>>> increase
>>>>>>> the number of  cores to 256, but let the local coarse space be
>>>>>>> defined
>>>>>>> again
>>>>>>> on  only 4 cores. Again, 192 solutions with these coarse spaces are
>>>>>>> required, but now this takes 0.24 seconds. The same for 1024 cores,
>>>>>>>  and we
>>>>>>> are at 1.7 seconds for the local coarse space solver!
>>>>>>> For me, this is a total mystery! Any idea how to explain, debug and
>>>>>>> eventually how to resolve this problem?
>>>>>>> Thomas
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121221/312cd24d/attachment-0001.html>
