[petsc-users] LU factorization and solution of independent matrices does not scale, why?
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri Dec 21 03:36:02 CST 2012
Okay, I did a similar benchmark now with PETSc's event logging:
UMFPACK
  16p: Local solve          350 1.0 2.3025e+01 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 63  0  0  0 52  63  0  0  0 51     0
  64p: Local solve          350 1.0 2.3208e+01 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 60  0  0  0 52  60  0  0  0 51     0
256p: Local solve          350 1.0 2.3373e+01 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 49  0  0  0 52  49  0  0  0 51     1
MUMPS
  16p: Local solve          350 1.0 4.7183e+01 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 75  0  0  0 52  75  0  0  0 51     0
  64p: Local solve          350 1.0 7.1409e+01 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 78  0  0  0 52  78  0  0  0 51     0
256p: Local solve          350 1.0 2.6079e+02 1.1 5.00e+04 1.0 0.0e+00
0.0e+00 7.0e+02 82  0  0  0 52  82  0  0  0 51     0
As you see, the local solves with UMFPACK have nearly constant time with
increasing number of subdomains. This is what I expect. The I replace
UMFPACK by MUMPS and I see increasing time for local solves. In the last
columns, UMFPACK has a decreasing value from 63 to 49, while MUMPS's
column increases here from 75 to 82. What does this mean?
Thomas
Am 21.12.2012 02:19, schrieb Matthew Knepley:
> On Thu, Dec 20, 2012 at 3:39 PM, Thomas Witkowski
> <Thomas.Witkowski at tu-dresden.de> wrote:
>> I cannot use the information from log_summary, as I have three different LU
>> factorizations and solve (local matrices and two hierarchies of coarse
>> grids). Therefore, I use the following work around to get the timing of the
>> solve I'm intrested in:
> You misunderstand how to use logging. You just put these thing in
> separate stages. Stages represent
> parts of the code over which events are aggregated.
>     Matt
>>      MPI::COMM_WORLD.Barrier();
>>      wtime = MPI::Wtime();
>>      KSPSolve(*(data->ksp_schur_primal_local), tmp_primal, tmp_primal);
>>      FetiTimings::fetiSolve03 += (MPI::Wtime() - wtime);
>> The factorization is done explicitly before with "KSPSetUp", so I can
>> measure the time for LU factorization. It also does not scale! For 64 cores,
>> I takes 0.05 seconds, for 1024 cores 1.2 seconds. In all calculations, the
>> local coarse space matrices defined on four cores have exactly the same
>> number of rows and exactly the same number of non zero entries. So, from my
>> point of view, the time should be absolutely constant.
>> Thomas
>> Zitat von Barry Smith <bsmith at mcs.anl.gov>:
>>>    Are you timing ONLY the time to factor and solve the subproblems?  Or
>>> also the time to get the data to the collection of 4 cores at a  time?
>>>     If you are only using LU for these problems and not elsewhere in  the
>>> code you can get the factorization and time from MatLUFactor()  and
>>> MatSolve() or you can use stages to put this calculation in its  own stage
>>> and use the MatLUFactor() and MatSolve() time from that  stage.
>>> Also look at the load balancing column for the factorization and  solve
>>> stage, it is well balanced?
>>>     Barry
>>> On Dec 20, 2012, at 2:16 PM, Thomas Witkowski
>>> <thomas.witkowski at tu-dresden.de> wrote:
>>>> In my multilevel FETI-DP code, I have localized course matrices,  which
>>>> are defined on only a subset of all MPI tasks, typically  between 4 and 64
>>>> tasks. The MatAIJ and the KSP objects are both  defined on a MPI
>>>> communicator, which is a subset of  MPI::COMM_WORLD. The LU factorization of
>>>> the matrices is computed  with either MUMPS or superlu_dist, but both show
>>>> some scaling  property I really wonder of: When the overall problem size is
>>>> increased, the solve with the LU factorization of the local  matrices does
>>>> not scale! But why not? I just increase the number of  local matrices, but
>>>> all of them are independent of each other. Some  example: I use 64 cores,
>>>> each coarse matrix is spanned by 4 cores  so there are 16 MPI communicators
>>>> with 16 coarse space matrices.  The problem need to solve 192 times with the
>>>> coarse space systems,  and this takes together 0.09 seconds. Now I increase
>>>> the number of  cores to 256, but let the local coarse space be defined again
>>>> on  only 4 cores. Again, 192 solutions with these coarse spaces are
>>>> required, but now this takes 0.24 seconds. The same for 1024 cores,  and we
>>>> are at 1.7 seconds for the local coarse space solver!
>>>> For me, this is a total mystery! Any idea how to explain, debug and
>>>> eventually how to resolve this problem?
>>>> Thomas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
