[petsc-users] Compiling 3.3 for Open-MPI on a SLURM system
Wed Dec 19 16:03:02 CST 2012
On Wed, Dec 19, 2012 at 4:54 PM, Gunter, David O <dog at lanl.gov> wrote:
> I am trying to compile PETSc on a SLURM-based system using GCC, openmpi-1.6.3.
> Here's my configure line:
> $ ./configure --prefix=/tmp/dog/petsc-3.3-p5 --with-mpiexec=mpiexec
> configure bombs out on this test:
> TESTING: configureMPITypes from config.packages.MPI(/usr/aprojects/hpctools/dog/petsc/petsc-3.3-p5/config/BuildSystem/config/packages/MPI.py:230)srun: error: slurm_send_recv_rc_msg_only_one: Connection timed out
> It should not be trying to srun anything as we use mpiexec with Open-MPI.  Any ideas?
If you can't run anything, you need --with-batch for the configure.
     Matt
> -david
> David Gunter
> HPC-3: Infrastructure Team
> Los Alamos National Laboratory
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
