[petsc-users] MUMPS Stuck
Nachiket Gokhale gokhalen at gmail.com
Thu Dec 13 17:03:13 CST 2012
The factorizations seem to be going through. It seem to take 40 mins or so
per factorization.
 -Nachiket
On Thu, Dec 13, 2012 at 5:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 13, 2012 at 1:44 PM, Nachiket Gokhale <gokhalen at gmail.com>
> wrote:
> > Thanks - should I attached the debugger in debug mode or in optimized
> mode?
> > I suspect it will be tremendously slow in debug mode, otoh I am not sure
> if
> > it will yield any useful information in optimized mode.
> Optimized will still give a stack trace.
> > Also, will -on_error_attach_debugger do the trick?
> No, either spawn one -start_in_debugger -debugger_nodes 0, or attach
> using gdb -p <proc id>
>    Matt
> >  -Nachiket
> > On Thu, Dec 13, 2012 at 4:29 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> On Thu, Dec 13, 2012 at 1:20 PM, Nachiket Gokhale <gokhalen at gmail.com>
> >> wrote:
> >> > I am trying to solve a complex matrix equation which was assembled
> using
> >> > MatCompositeMerge using MUMPS and LU preconditioner. It seems to  me
> >> > that
> >> > the solve is stuck in the factorization phase. It is taking 20 mins or
> >> > so,
> >> > using 16 processes.  A problem of the same size using reals instead of
> >> > complex was solved previously in approximately a minute using 4
> >> > processes.
> >> > Mumps output of -mat_mumps_icntl_4 1  at the end of this email.  Does
> >> > anyone
> >> > have any ideas about what the problem maybe ?
> >> Complex arithmetic is much more expensive, and you can lose some of
> >> the optimizations
> >> made in the code. I think you have to wait longer than this. Also, you
> >> should try attaching
> >> the debugger to a process to see whether it is computing or waiting.
> >>    Matt
> >> > Thanks,
> >> > -Nachiket
> >> > Entering ZMUMPS driver with JOB, N, NZ =   1      122370
>  0
> >> >  ZMUMPS 4.10.0
> >> > L U Solver for unsymmetric matrices
> >> > Type of parallelism: Working host
> >> >  ****** ANALYSIS STEP ********
> >> >  ** Max-trans not allowed because matrix is distributed
> >> >  ... Structural symmetry (in percent)=  100
> >> >  Density: NBdense, Average, Median   =    0   42   26
> >> >  Ordering based on METIS
> >> >  A root of estimated size         2736  has been selected for
> Scalapack.
> >> > Leaving analysis phase with  ...
> >> > INFOG(1)                                       =               0
> >> > INFOG(2)                                       =               0
> >> >  -- (20) Number of entries in factors (estim.) =       563723522
> >> >  --  (3) Storage of factors  (REAL, estimated) =       565185337
> >> >  --  (4) Storage of factors  (INT , estimated) =         3537003
> >> >  --  (5) Maximum frontal size      (estimated) =           15239
> >> >  --  (6) Number of nodes in the tree           =            7914
> >> >  -- (32) Type of analysis effectively used     =               1
> >> >  --  (7) Ordering option effectively used      =               5
> >> > ICNTL(6) Maximum transversal option            =               0
> >> > ICNTL(7) Pivot order option                    =               7
> >> > Percentage of memory relaxation (effective)    =              35
> >> > Number of level 2 nodes                        =              35
> >> > Number of split nodes                          =               8
> >> > RINFOG(1) Operations during elimination (estim)=   4.877D+12
> >> > Distributed matrix entry format (ICNTL(18))    =               3
> >> >  ** Rank of proc needing largest memory in IC facto        :         0
> >> >  ** Estimated corresponding MBYTES for IC facto            :      3661
> >> >  ** Estimated avg. MBYTES per work. proc at facto (IC)     :      2018
> >> >  ** TOTAL     space in MBYTES for IC factorization         :     32289
> >> >  ** Rank of proc needing largest memory for OOC facto      :         0
> >> >  ** Estimated corresponding MBYTES for OOC facto           :      3462
> >> >  ** Estimated avg. MBYTES per work. proc at facto (OOC)    :      1787
> >> >  ** TOTAL     space in MBYTES for OOC factorization        :     28599
> >> > Entering ZMUMPS driver with JOB, N, NZ =   2      122370
>  5211070
> >> >  ****** FACTORIZATION STEP ********
> >> >  GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
> >> >  NUMBER OF WORKING PROCESSES              =          16
> >> >  OUT-OF-CORE OPTION (ICNTL(22))           =           0
> >> >  REAL SPACE FOR FACTORS                   =   565185337
> >> >  INTEGER SPACE FOR FACTORS                =     3537003
> >> >  MAXIMUM FRONTAL SIZE (ESTIMATED)         =       15239
> >> >  NUMBER OF NODES IN THE TREE              =        7914
> >> >  Convergence error after scaling for ONE-NORM (option 7/8)   =
> 0.79D+00
> >> >  Maximum effective relaxed size of S              =   199523439
> >> >  Average effective relaxed size of S              =    98303057
> >> >  REDISTRIB: TOTAL DATA LOCAL/SENT         =      657185    14022665
> >> >  GLOBAL TIME FOR MATRIX DISTRIBUTION       =      0.4805
> >> >  ** Memory relaxation parameter ( ICNTL(14)  )            :        35
> >> >  ** Rank of processor needing largest memory in facto     :         0
> >> >  ** Space in MBYTES used by this processor for facto      :      3661
> >> >  ** Avg. Space in MBYTES per working proc during facto    :      2018
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which
> >> their experiments lead.
> >> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121213/31babfcc/attachment-0001.html>
