[petsc-users] MUMPS Stuck
Nachiket Gokhale gokhalen at gmail.com
Thu Dec 13 15:20:37 CST 2012
I am trying to solve a complex matrix equation which was assembled using
MatCompositeMerge using MUMPS and LU preconditioner. It seems to  me that
the solve is stuck in the factorization phase. It is taking 20 mins or so,
using 16 processes.  A problem of the same size using reals instead of
complex was solved previously in approximately a minute using 4 processes.
Mumps output of *-mat_mumps_icntl_4 1  *at the end of this email.  Does
anyone have any ideas about what the problem maybe ?
-Nachiket
Entering ZMUMPS driver with JOB, N, NZ =   1      122370              0
 ZMUMPS 4.10.0
L U Solver for unsymmetric matrices
Type of parallelism: Working host
 ****** ANALYSIS STEP ********
 ** Max-trans not allowed because matrix is distributed
 ... Structural symmetry (in percent)=  100
 Density: NBdense, Average, Median   =    0   42   26
 Ordering based on METIS
 A root of estimated size         2736  has been selected for Scalapack.
Leaving analysis phase with  ...
INFOG(1)                                       =               0
INFOG(2)                                       =               0
 -- (20) Number of entries in factors (estim.) =       563723522
 --  (3) Storage of factors  (REAL, estimated) =       565185337
 --  (4) Storage of factors  (INT , estimated) =         3537003
 --  (5) Maximum frontal size      (estimated) =           15239
 --  (6) Number of nodes in the tree           =            7914
 -- (32) Type of analysis effectively used     =               1
 --  (7) Ordering option effectively used      =               5
ICNTL(6) Maximum transversal option            =               0
ICNTL(7) Pivot order option                    =               7
Percentage of memory relaxation (effective)    =              35
Number of level 2 nodes                        =              35
Number of split nodes                          =               8
RINFOG(1) Operations during elimination (estim)=   4.877D+12
Distributed matrix entry format (ICNTL(18))    =               3
 ** Rank of proc needing largest memory in IC facto        :         0
 ** Estimated corresponding MBYTES for IC facto            :      3661
 ** Estimated avg. MBYTES per work. proc at facto (IC)     :      2018
 ** TOTAL     space in MBYTES for IC factorization         :     32289
 ** Rank of proc needing largest memory for OOC facto      :         0
 ** Estimated corresponding MBYTES for OOC facto           :      3462
 ** Estimated avg. MBYTES per work. proc at facto (OOC)    :      1787
 ** TOTAL     space in MBYTES for OOC factorization        :     28599
Entering ZMUMPS driver with JOB, N, NZ =   2      122370        5211070
 ****** FACTORIZATION STEP ********
 GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
 NUMBER OF WORKING PROCESSES              =          16
 OUT-OF-CORE OPTION (ICNTL(22))           =           0
 REAL SPACE FOR FACTORS                   =   565185337
 INTEGER SPACE FOR FACTORS                =     3537003
 MAXIMUM FRONTAL SIZE (ESTIMATED)         =       15239
 NUMBER OF NODES IN THE TREE              =        7914
 Convergence error after scaling for ONE-NORM (option 7/8)   = 0.79D+00
 Maximum effective relaxed size of S              =   199523439
 Average effective relaxed size of S              =    98303057
 REDISTRIB: TOTAL DATA LOCAL/SENT         =      657185    14022665
 GLOBAL TIME FOR MATRIX DISTRIBUTION       =      0.4805
 ** Memory relaxation parameter ( ICNTL(14)  )            :        35
 ** Rank of processor needing largest memory in facto     :         0
 ** Space in MBYTES used by this processor for facto      :      3661
 ** Avg. Space in MBYTES per working proc during facto    :      2018
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121213/d19620ad/attachment.html>
