[petsc-users] question of a Brazilian student about the use of "PETSC" in a cluster
Marcelo Guterres m.guterres at gmail.com
Thu Dec 13 04:55:10 CST 2012
Hello,
My name is Marcelo Guterres and I am PhD student in Brazil.
I use the PETSC in a cluster with 11 computers, each with 8 processors
"Xeon 2.8GHz", "16GB RAM" and "4 HD SAS" from "146GB".
My question is about the PETSc following functions:
/    -> Ierr = MPI_Comm_rank (MPI_COMM_WORLD, & rank); CHKERRQ (ierr);
     -> Ierr = MPI_Comm_size (MPI_COMM_WORLD, & size); CHKERRQ (ierr);/
For example, using only MPI:
// Program hello word using MPI
#include <iostream>
using namespace std;
#include <mpi.h>
int main(int argc, char *argv[])
    int size, rank;
    MPI_Init(&argc, &argv);
    MPI_Comm_size(MPI_COMM_WORLD,&size);
    MPI_Comm_rank(MPI_COMM_WORLD,&rank);
    cout << "hello. I am process " << rank << " of " << size << endl;
    if ( rank == 0)
        cout << "\nFinish !!" << endl;
    MPI_Finalize();
*****  running the command has the following output:*
[guterres at stratus hello]$ mpirun -np 3 ./hello
hello. I am process 1 of 3
hello. I am process 0 of 3
Finish !!
hello. I am process 2 of 3
CONCLUSION: int size = 3;
using only the PETSC
static char help[] ="\n\n hello word PETSC !!";
#include <iostream>
#include <petscsys.h>
int main( int argc, char *argv[] )
    PetscErrorCode  ierr;
    PetscMPIInt  size,
                        rank;
    ierr = PetscInitialize(&argc,&argv,(char *)0,help);CHKERRQ(ierr);
    ierr = MPI_Comm_rank(MPI_COMM_WORLD,&rank); CHKERRQ(ierr);
    ierr = MPI_Comm_size(MPI_COMM_WORLD,&size); CHKERRQ(ierr);
    if ( rank == 0)
        cout << "\nfinish !!" << endl;
    ierr =  PetscFinalize( ); CHKERRQ(ierr);
    return 0;
[guterres at stratus hello_petsc]$ mpirun -np 3 ./hello
hello. I am process 0 of 1
finish !!
finish !!
finish !!
*MY QUESTION IS:*
THE OUTPUT OF THE PROGRAM WITH PETSC CORRECT???
the variable value PetscMPIInt  size = np ??
The correct output should not be:
finish !!
CONCLUSION: PetscMPIInt size = 3 ??
Thank you for your attention and excuse my writing in English.
Marcelo Guterres
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121213/8c07310c/attachment.html>
