[petsc-users] Creating explicit matrix scatter
Thomas Witkowski thomas.witkowski at tu-dresden.de
Sat Dec 8 08:33:57 CST 2012
I checked the documentation of MatGetSubMatrix() and found the following:
"The rows in isrow will be sorted into the same order as the original
matrix on each process."
For my case, this will be wrong. I need to say each task exactly which
row from the old matrix should be which row in the new matrix. Any other
possibility to do this?
Thomas
Am 08.12.2012 15:12, schrieb Jed Brown:
> MatGetSubMatrix() and later, MatGetRow()
> On Sat, Dec 8, 2012 at 5:59 AM, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>     A have a distributed MATAIJ, which is non square. I want to create
>     a new matrix, which has the same col layout but a different row
>     layout and should be scattered from the original matrix. Thus,
>     each rank should collect some rows, which may be non local in the
>     original matrix, to its own local part of the new matrix. After
>     creating the new matrix, I need not only to make some MatMult, but
>     I need local access to the matrix rows. How to do this? Thanks for
>     any advise.
>     Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121208/f0c79cc6/attachment.html>
