[petsc-users] Is there something to be paid attention to about MatIsSymmetric?
w_ang_temp w_ang_temp at 163.com
Sun Dec 2 12:09:06 CST 2012
Maybe the matrix in my project is true unsymmetric. I use MatIsTranspose and get
the same result. Maybe I need to check my constitutive model.
>At 2012-12-02 23:10:51,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>The test for symmetry is not implemented for all matrix types. Looking at the code, it seems to only be SeqAIJ, but MatIsTranspose(A,A,...) would also work >for MPIAIJ.
>>On Sun, Dec 2, 2012 at 8:45 AM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>Hello,
>>    I use MatIsSymmetric to know if the matrix A is symmetric.
>>According to my model, it should be symmetric due to the theory.
>>But I always get the result 'PetscBool  *flg = 0', although I
>>set 'tol' a large value(0.001).
>>    Because the matrix is of 20000 dimension, I can not output the
>>matrix to the txt. So I want to konw if there is something to be paid attention to
>>about the function 'MatIsSymmetric' in version 3.2. Or do I have some other ways
>>to determine the symmetry.I think symmetry is one of the most important thing
>>in my analysis.
>>    Thanks.
>>                                               Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121203/1f8e01f9/attachment.html>
